YM 1700 sleeves
   / YM 1700 sleeves #1
kryp
Can anyone tell me if the YM 1700 has wet or dry cyl seelves?
   / YM 1700 sleeves
You are a great help to me Allen, I think the water is passing the o-rings on the seelves to the base. Now do you sell parts buddy?
   / YM 1700 sleeves #4
No I don't. You need to talk with Leonard, Bruce or one of the other dealers that frequent this board.
   / YM 1700 sleeves #5
The YM1700 sleeves are no longer available. The good news is you can use YM2000 sleeves, pistons, and head gasket and therefore have a bit more horses.
Thanks,
Bruce
parts@yanmartractors.com
866 794 4498
   / YM 1700 sleeves
ygm.... and I will phone you tomorrow.
   / YM 1700 sleeves #7
Does the block have to be machined to accept the ym2000 sleeves? or is the outside diameter the same?
How much more HP do you estimate with the new pistons, etc.
Does this cause any valve problems?
Chris
   / YM 1700 sleeves #8
The sleeves fit with no machining because the blocks are the same. It is hard to estimate HP because the injector pumps are different. No valve problems.
Thanks,
Bruce
   / YM 1700 sleeves #9
This looks like a question for ( drum roll ) Roger Scotty (echo)
Roger... hypothetically replacing a ym1700 cylinder sleeves with ym2000, and acompianing pistons, etc.
Is ther more CI displacement? I'm assuming yes... if the id of the sleeves is less than the 1700's. Now, the injector pump is still calibrated for the lower ci... will there be mixture problems ( lean? etc? ) ( higher air volume... same amount of fuel injected )or will it be necescary to adjust the pump, or would it run without adjustment?
Just wondering...
Chris / Soundguy
"The sleeves fit with no machining because the blocks are the same. It is hard to estimate HP because the injector pumps are different. No valve problems.
Thanks,
Bruce "
   / YM 1700 sleeves #10
Since the HP will increase, what about engine cooling? Since the 1700 does not have a water pump, I would assume the propensity for overheating will increase? Just wondering if anyone has already been through a 1700 rebuild and used YM2000 piston/sleeves?
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
FAKE (A52472)
FAKE (A52472)
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
