SailorBob
Fortunately it is stuck in th 540 rpm range but, I cannot shift it into neutral. Everything seems to work Ok ecept for that. When I depress the clutch the pto does top turning. I wonder if something has vibrated loose. I noticed that the clutch pedal has linkage attached to a lever on the side of the PTO as well. I do not see anything moving when I press the clutch. It seem that it should move the lever on the PTO. I have a service manual for a YM195 but, It is not clear enough to tell if it is connected correctly or if something has just vibrated out of adjustment. Does anyone have any ideas or could someone post a photo of their setup.
Fortunately, I can still use the tractor I just have to be careful. /forums/images/graemlins/shocked.gif
Any input would be appreciated.
