YM 1500D and Sunpro Gauges
/ YM 1500D and Sunpro Gauges #1
SheriffSRB
Oconee Co Georgia
Yanmar 1500D
Good morning all. I am in the process of installing my 1.5 inch Sunpro oil pressure and water temp gauges, along with my voltmeter. I will post pics when I am done, but I just wanted to say that all the hints, previous posts and info ya'll have provided have made this easy for me. Got the right adapters, etc on the first trip to the parts store. And by the way, this little unit is running 40 psi on oil pressure. I will have the rest of the gauges installed by the end of the week. I do have to really work every now and then. For you purists out there, I am drilling holes in the dash to mount the gauges.
My next project will involve wiring, since none of the light switches, turn signals, etc work, but I will save that for another post.
Again, thanks to everyone who contributes to this board. I hope that in the future I will be helpful to someone as well.
/ YM 1500D and Sunpro Gauges #2
Congrats on gettting the gauges in. I love them. The 40 for oil seems good to me...that what my 1500 does.
If you need a wiring diagram, one is in the translated manual from Hoye Tractor . I have one for the 1500 and the diagram is in the back. Hoye are good people and supporting them also supports your future parts availability.
Good luck
Peter
/ YM 1500D and Sunpro Gauges #3
A while back you did a post on installing a voltmeter. Did you ever complet the project and hoq did you connect the wiring ?
I'm trying to install a voltmeter on my yanmar 1500. a reply sure would be welcome. thank you.
/ YM 1500D and Sunpro Gauges #4
/ YM 1500D and Sunpro Gauges #5
A voltmeter is the easiest gauge you can hookup on a tractor.
Get the volt meter, mount it, run it's '-' wire to the battery '-', and then run the gauges '+' wire to the switched side of your ignition switch. When you turn the key on, you will see battery condition, as well as be able to monitor it while using the tractor.
( this assumes a negative ground system )
Soundguy
/ YM 1500D and Sunpro Gauges #6
Soundguy
/ YM 1500D and Sunpro Gauges #7
Soundguy,
Sorry. Instead of a voltmeter I have a D C amp meter. Whould it connect the same way? I, getting sparks when I try to connect this way.
/ YM 1500D and Sunpro Gauges #8
Soundguy,
/ YM 1500D and Sunpro Gauges #9
An Ammeter is a parallel circuit your have to cut the charge line and run the wire through the gage. On these tractors the Alt. generates AC voltage so you have to cut in after the voltage reg.
Soundguy, correct me if I'm wrong. I've done it on cars but never a tractor.
Tom
/ YM 1500D and Sunpro Gauges #10
Tom
/ YM 1500D and Sunpro Gauges #11
</font><font color="blue" class="small">( An Ammeter is a parallel circuit )</font>
Actually.. an ammeter is a series device.. a voltmeter is a parallel device. You insert an ammeter into a circuit, you attach a voltmeter across a circuit. My previous post tells exactly how to install the volt meter.
</font><font color="blue" class="small">( On these tractors the Alt. generates AC voltage so you have to cut in after the voltage reg. )</font>
If we are talking about a volt meter, then i would install it as imentioned. referencing ground, and power from t he switched side of the ignition. If you are talking ammeter.. then, technically you coul dinstall it in an ac or dc line.. all it is is a shunt volmenter.. it will still measure current flow..e tc.... however most ammeter setup I see are to measure net charge/discharge from the battery, and are wired so that one side of the meter has all the loads, and the other is what is tied to the battery.
Soundguy
/ YM 1500D and Sunpro Gauges #12
Soundguy
/ YM 1500D and Sunpro Gauges #13
</font><font color="blue" class="small">( Sorry. Instead of a voltmeter I have a D C amp meter. Whould it connect the same way )</font>
NO.. an ampmenter is a series device.. it's actually a shunt.. if you connected an ampmeter the way i told you to connect a volt meter.. you may have damaged the shunt ampmeter.
Ampmeters get connected in line.. not across. I'd find the charge wire that goes to t he battery, and connectt he ampmeter into that line.. that is.. one side to the meter.. the other side of the meter to the battery.. or wherever the charge line is hooked.. like the solenoid hot side.. etc..
Please be specific when asking for electrrical advice.. especially on 2 very different itemps like volt meters, and ammeters..
Soundguy
soundguy
/ YM 1500D and Sunpro Gauges #14
Soundguy
soundguy
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
SCAN TO RECEIVE TEXT UPDATES (A60430)
SCAN TO RECEIVE...
2000 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2000 Freightliner...
7065CFL (A59228)
7065CFL (A59228)
