YM 1401 Brakes
/ YM 1401 Brakes #21
/ YM 1401 Brakes #22
Thanks Aaron, that makes a lot more sense. As usual, "you da man".
/ YM 1401 Brakes #23
You do not remove the friction material. You remove a little bit off of the metal pad that rests on the cam.... if needed. You can use a file, die grinder, or hand grinder. It is an easy job and takes less than a minute. It is pretty uncommon to need to do that but it does happen occasionally if the circumstances are just right. Some linings are extra thick for some reason (see below).
Unfortunately, this is just another case where there is just not enough demand for a product. There is just one company having these made and we are at their mercy. The quality is fine for what they are but could certainly be better. They function just fine and durability is fine but there are some irregularities with the initial fit. I just don't have the budget right now to get a few thousand shoes made that fit only 1 model. The minimum production run would last us about 60 years. :)
My bad...sorry all. Mis-read Aaron's instructions
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2014 FORD F-150 (A65643)
2014 FORD F-150...
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
Gehl Mix-All 95 Grinder Mixer (A66408)
Gehl Mix-All 95...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
