Yet another carry-all
/ Yet another carry-all #11
No, just bolted thru the last board. I won't tow anything with it other than the log splitter or a yard cart. If I was going to pull something more substantial, I'd consider reinforcing it.
Thanks, was just curious as I'm tempted to use it for tools/devices (e.g. vices, lifts) made to use the 2" receiver interface so I can use the carry all as a portable workbench if/when needed.
Think I may go the enforced route since I'm apparently not the only one that would consider reinforcing it for heavier applications.
/ Yet another carry-all #12
Nice job, I like it when good things are made out of leftover materials.
I hope it serves you for many years!
/ Yet another carry-all #13
I've got the same setup Tartan frame with cedar decking boards.
Recently, another pair of pin holes 5 inches lower down the vertical frame members were drilled using a hole saw. The carry all still rests on the ground when lowered, but it also raises to a height very useful for serving as a lift to feed the splitter. As delivered, the pins were too high for the B7200.
I'm taking a break from using it in that way rigth now. It's Hot out there!
/ Yet another carry-all #14
Good idea for more lift. My lower link tips almost touch the ground and since I don't have any attachments with pins that low, it seems like a waste of lift distance. Thought about indexing the spline on the rockshafts a tooth or two to shift the range of motion up to a more useful position but forgot about it until just now.
/ Yet another carry-all #15
Great job! Thanks for posting you just gave me an idea.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2016 FREIGHTLINER CASCADIA 125 6X4  T/A  SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2011 DOOSAN G40 GENERATOR (A60736)
2011 DOOSAN G40...
