Yet another carry-all
/ Yet another carry-all #1
rbstern
GA
LS MT225E, Yanmar 2210
Bought a new log splitter, and looking for ways to make my processing setup more efficient. Already had the County Line carry all frame. Had been using it with a customized pallet for similar purposes. Decided to build the same style carry-all that most seem to like. The wood was already on hand, in the "leftovers" pile from our 2018 house build. Nothing unique about the build, except I mounted a Husqvarna Powerbox using a clamping lamp bracket. It's removable, or can be swapped to be carried on the back side of the carryall. Hearing and eye protection, small tools, oil, etc., go in the box.
Needs a coat of stain or paint, just haven't gotten to that yet.
Total out of pocket build cost: $20 for the carriage bolts, washers and nuts, bought by the pound at TSC.
/ Yet another carry-all #2
(y) Are planning to add front weight?
The yanmar has 180 pounds of suitcase weights, and the front tires are filled. Wouldn't mind adding another 100 lbs. Have an LS with FEL. Serious loads will be handled by the LS. Didn't have any problem with what I did today using the yanmar.
/ Yet another carry-all #5
Being able to pull your splitter like that gives you a whole lot more options on how you work (y)
gg
Thanks for the positive comments.
/ Yet another carry-all #9
Nice build ...am thinking of doing similar to mine when I get a frame.
Did you attach the receiver hitch to just the one back board or did you run another board from the front to the back tying all the bottom boards together?
No, just bolted thru the last board. I won't tow anything with it other than the log splitter or a yard cart. If I was going to pull something more substantial, I'd consider reinforcing it.
/ Yet another carry-all #11
Thanks, was just curious as I'm tempted to use it for tools/devices (e.g. vices, lifts) made to use the 2" receiver interface so I can use the carry all as a portable workbench if/when needed.
Think I may go the enforced route since I'm apparently not the only one that would consider reinforcing it for heavier applications.
/ Yet another carry-all #12
Nice job, I like it when good things are made out of leftover materials.
I hope it serves you for many years!
/ Yet another carry-all #13
I've got the same setup Tartan frame with cedar decking boards.
Recently, another pair of pin holes 5 inches lower down the vertical frame members were drilled using a hole saw. The carry all still rests on the ground when lowered, but it also raises to a height very useful for serving as a lift to feed the splitter. As delivered, the pins were too high for the B7200.
I'm taking a break from using it in that way rigth now. It's Hot out there!
/ Yet another carry-all #14
Good idea for more lift. My lower link tips almost touch the ground and since I don't have any attachments with pins that low, it seems like a waste of lift distance. Thought about indexing the spline on the rockshafts a tooth or two to shift the range of motion up to a more useful position but forgot about it until just now.
/ Yet another carry-all #15
Great job! Thanks for posting you just gave me an idea.
2019 WESTERN GLOBAL DOUBLE WALLED FUEL TANK (A64279)
2019 WESTERN...
Can Am Defender (A63688)
Can Am Defender...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2018 John Deere 50G (A64126)
2018 John Deere...
2018 CATERPILLAR 259D SKID STEER (A64279)
2018 CATERPILLAR...
