Yet Another Box Blade Question
/ Yet Another Box Blade Question #1
Harv
Elite Member
California - S.F. East Bay & Sierra foothills
Kubota L2500DT Standard Transmission
Okay, now that I'm approaching 50 hours of actual seat time (almost caught up with Mark Chalkley, I believe), I thought I was starting to understand the box scraper. But... NOOOOOOOOOO!!!
My final chore over the weekend was to try to create a walking path for my elderly mother, running maybe 100 yards from the front of the house up to a spot next to the road where she likes to ogle the neighbor's front gate (don't ask me why -- she is quite senile, unfortunately). At 86, she walks with the aid of a cane and requires a pretty good surface to avoid mishaps. No problem -- I have a box blade! /w3tcompact/icons/cool.gif
I had already flattened and smoothed the entire acreage in that area, mostly so I could control weeds more easily, but now I wanted to create a strip of the smoothest, firmest earth I possibly could. I made a few passes with casual scraping, just to remove as much of the loose surface dirt and small rocks as I could. Then I tried to get serious about creating a mirror surface (I like to set high goals) for Mom to walk on.
Although basically cleared and flat now, the path had the usual pits and valleys from turning up rocks and the general unevenness of the soil firmness. I made another pass or two, playing with the angle of the blade and position control settings. If I used too much lift, there would be areas where my tire tracks were not erased, so I wound up pretty much leaving the full weight of the box on the ground.
So now I was back to the much-discussed tip angle of the blade(s). Seeing this as a real learning experience, I tried both extremes just to observe the results. Tilting all the way forward (back end high) did pretty much as expected -- hogged right in and started turning up more shallow rocks. What surprised me was the other extreme -- tilted all the way back (front end high), the box filled more rapidly than ever! /w3tcompact/icons/shocked.gif It wasn't turning up so many rocks (it either slid over them or dragged them, creating grooves in my path), but was pulling up mounds of fine dirt. My present (and only) theory is that the extreme tilt brought the frame of the box itself into play as a scraping surface, leaving the hinged rear blade with little to do.
I got my very best results (smoothest surface) with the box set almost perfectly flat, giving the front and rear blades nearly equal opportunity to affect the soil. My question to my more experienced colleagues out there, and to our affluent, hydraulically enhanced top link friends, is this -- do you find that you do most of your box-scraping near the "flat" position, with only minor adjustments on the tilt, or have you discovered good reasons for going to the extremes?
/ Yet Another Box Blade Question #2
Harv, if I recall you have a hinged back on your blade? That will behave quite differently than a fixed back one. I have a fixed back and when I tip it way up (lengthen top link) it rides on that rear blade leaving a very nicely smoothed surface behind /w3tcompact/icons/smile.gif
/ Yet Another Box Blade Question #3
Harv,
As a boxblade non-owner and resident boxblade cynic, I am happy to offer my completely unhelful observations to your problem.
1. Boxblades dont work well unless they weigh at least 800-1200 lbs, in which case they cost over $1K.
2. Boxblades dont work well unless you have typo-N-tilt, which costs another $1K.
3. Even when the above conditions are satisfied, boxblades dont work well unless you continuously make microscopic adjustments to the toplink, which no one can explain.
4. Boxblade microscopic manipulation technique depends on whether you have a fixed blade box, a hinged blade box, a rollover box, a high back box or low back box.
5. No one in the universe, or at least on TBN or CTB, can explain the different boxes listed in point 4.
6. Other than all of the above, boxblades are an extremely user-friendly and prodigiously effective tool.
7. The scariest part is that I'm thinking of getting one.
Now I'll let the experts provide the real solutions.
/ Yet Another Box Blade Question #4
Harv,
You failed to mention whether your rear blade was locked or hinged.
My rear blade is the fixed variety, and when I have the box tilted back (front high), fresh material is picked up by the front blade only when it exceeds the height of the front blade. Since the back blade is angled backward, it just smooths things out. Also when the box is in this position, it dumps excess material very quickly.
I fail to understand the usefulness of the hinged rear blade. /w3tcompact/icons/frown.gif
The GlueGuy
/ Yet Another Box Blade Question #5
This has probaably already been discussed but...
I have ben trying to smooth out a road that has peaks and valleys running left and right across the road. The peaks and valleys are perhaps 2 or three feet long. As I begin to ride up the peak, the box digs into the valley behind me, then as I go down the peak, the box raises and deposits the new soil at the peak, making the situation worse instead of better. The only solution so far is for me to CONSTANTLY raise and lower the box, attempting to deposit in the valley and trim the tops of the peaks. There must be a better way....
/ Yet Another Box Blade Question #6
I love our "resident cynic's" response./w3tcompact/icons/laugh.gif
Harv, I've never used a box blade with the hinged rear blade. Can't it be locked in position so it'll work like a fixed blade?
I've tried all the different ways I could think of, with varying degrees of success in the past, but just for smoothing, the thing that works best for me is to tilt it back (lengthen top link) so it rides on the rear blade as you're going forward. Of course, that meant picking it up at the end of a run and turning around before I put the hydraulic top 'n tilt on. Now I tilt it back (not quite all the way) to run forward, then tilt it forward (still not all the way) and run backwards, and going back and forth a few times like that seems to work better than anything else I've tried. I have enough travel distance on my top link cylinder that if I tilt it all the way forward, it's riding on the front corners of the side plates with the blades off the ground, so that won't work for smoothing in reverse, or for digging going forward.
Bird
/ Yet Another Box Blade Question #7
I was also frustrated /w3tcompact/icons/mad.gif The more I did, the worse it looked. I finally “got aggressive” and lowered the scarifiers. First I went forward over the high spots, raising and lowering the box. Then I did the same in reverse, backfilling into the low. Ripped it all up and then, a few passes with the FEL blade at a slight angle, in reverse, and I was done. The rains then packed it down nice and level /w3tcompact/icons/smile.gif
Mark
/ Yet Another Box Blade Question #8
Mark, I, too, had better luck with the front end loader running the tractor backwards until I put the hydraulic top 'n tilt on, so now I can do a better job with the box blade than the bucket edge.
Bird
/ Yet Another Box Blade Question #9
Glenn,
Too Funny/w3tcompact/icons/smile.gif Good post.
Al
/ Yet Another Box Blade Question #10
Harv - Only 50 hours of seat time? You've got more time than that on your cup...
Glenn - I hadn't seen enough of your posts to realize you were the "resident box scraper cynic", but I believe it now! Truth be told, I've never been all that crazy about them myself, but they have their uses. If you looked at my recent pictures in the "L4310 enhancements" thread, for example, you can see one holding down my pallet forks for transport purposes...
All seriousness aside, I've found that "glass-smooth surfaces" (Harv) are most easily accomplished by raising the front of the box scraper (with the hydraulic top link, of course) until the front blade is just slightly higher than the back one, if I'm going forward, and vice versa when going backward (not recommended).
Of course, what works best of all is to turn it on its end and just drag it around on its end plate, but this is hard to do without removing it from the tractor and hooking a chain to it, and people who have never used a box scraper before tend to regard you as an amateur when they see you use it this way. /w3tcompact/icons/wink.gif
MarkC
/ Yet Another Box Blade Question #11
I have a suggestion, but unfortunately its alot of manual labor. I watched the crew at city park last summer put in a walking/running path. The process was pretty simple, and resulted in a perfectly flat, hard surface.
They used 1 by 4s on edge, held in place with 1 by 2 stakes driven in the ground. Level the top of the 1 by 4s and then filled with a very fine crushed gravel. Use a 2 by 4 to level the gravel in the "forms", then move dirt up to the sides of the boards. The result is a path, that is smooth and can be mowed across very easily since the boards do not extent above the surface when complete.
In order the reduce the amount of gravel used, they put the 1 by 4s about 1/2 way in the ground. That way less than 2" of gravel is needed.
If your ground isnt extremely hard, this should be simple and fairly inexpensive to put in. You can use your tractor to deliver the gravel where needed and to contour the dirt.
/ Yet Another Box Blade Question #12
Harv!
I'm guessing you need to "fix" that hinged rear blade. Otherwise, it is flapping out of the way, and then you are still catching your front blade.
You can borrow my roll-over scraper if you'd like(have'nt sold it yet). That is one situation where it works REALLY well...
RobertN in Shingle Springs Calif
/ Yet Another Box Blade Question #13
Glenn-
I'm certainly no expert, but can't resist jumping in. True, the heavier the better, but there are lots of guys moving dirt with the lighter ones. The trouble with the heavy ones, besides $$ is they usually have hydraulic scarifiers. Nice, but requires 5th SCV. Even with the heavy ones it is imperative to work the ground up with scarifiers first. I even scarify the fill areas as it makes a better bond. Also important is keeping some material in the box so you have something to drop in the low spots.
Top'nTilt - Essential
Microscopic Adjustments - I gave up trying to make fine adjustments with the rockshaft lever - I can't tell I've moved the box until the dirt starts falling out. I just bump the top link lever for this. Mine are spring loaded and return to "neutral" - don't know if they're all like this or not.
I once watched a guy running a grader that had a row of about a dozen SCV's and he would just go along this "keyboard", bumping these controls to make the blade and carriage do what he wanted.
A light box with fixed rear blade and a heavy box with hinged rear blade are two different animals. I only recently unbolted my hinged rear blade so it swings free, and so far I like it that way.
Never used a rollover - I bet Murf on CTB has.
High back holds more dirt- good if you have the hp and traction to pull it.
Landpride and gearmore both sell a boxblade with manually retractable scarifiers - one lever controls all the scarifiers in one move.
Also, I have found scarifiers on a box scraper to be usefull to break up the soil prior to rototilling - saves wear and tear on the tiller.
BTW - Harv - Maybe what you need is a landscape rake to get rid of those rocks. If you're like me, you don't need much justification to get a new toy. - Stan
/ Yet Another Box Blade Question #14
Stan,
Welcome to the forum. Your comments are helpful.
I am confused about the hinged back. Does it swing both ways? If it swings backwards, you couldn't "ride" the back blade. If it only swings forward (toward the front blade), I guess I could see some use for it. But it would only seem to make sense if you could lock it.
I am looking in a current Woods Landscape catalog. The high-end Woods, Gill and Gannon boxscrapers all seem to have lockable hinged backs. Some insight into the hinged back can be gotten from some blurbs in the catalog. Re the Woods HB scrapers: "HB series scrapers feature a floating hinged tailgate which allows the front cutting edge to operate more freely in heavy grading conditions." Re the Gill boxscrapers: "The large, hinged tailgate floats, freeing the moldboard to dig or draft for heavy grading applications. A pin locking mechanism fixes the tailgate in place for smooth, precision leveling." The boldface was added by me, and may be the answer to Harv's problem.
Of course, this is all theory to me, as I have yet to see an actual boxblade at any dealer in CT, except for one dealer who has a few fixed blade types made by United.
/ Yet Another Box Blade Question #15
To continue my entirely theoretical discussion with myself, here is how I hypothesize a hinged back box works and what Harv's problem is.
With a fixed blade box: when you are on the front blade you are digging/scraping. As you lengthen the toplink you increase the aggressiveness of the dig angle until such point that further lengthening rolls the box onto the back blade. With this back blade, so people claim, you can smooth.
With a hinged back blade: you lengthen thr toplink to increase the dig angle but you never roll onto the back blade because it swings out of the way. Thus, you get ever increasing scraping aggression until you roll the front blade off the ground and the box is on its haunches. This sounds like what Harv is experiencing.
By locking the hinged back, you can roll onto the back blade just as if the box were a fixed blade box. So, Harv should lock his back blade.
Does any of this sound plausible?
<P ID="edit"><FONT SIZE=-1>Edited by glennmac on 07/16/01 08:31 PM (server time).</FONT></P>
/ Yet Another Box Blade Question #16
Yup as long as he can lock it in place. Some boxes you can some you can't. Well Harv if you can't lock that rear blade looks like it's time to buy a welder and make up some pins to lock that rear blade in place./w3tcompact/icons/smile.gif
Gordon
/ Yet Another Box Blade Question #17
Harv can you lock your rear blade in place??? That is the key to using the box with it tilted way back. If you can't lock your gate then level is the way to go. I also posted that it's about time for a welder isn't it? That is if your rear gate doesn't lock at this time. With a welder it sure could easy enough.
Gordon
/ Yet Another Box Blade Question #18
Well, I'm still missing something. What's the purpose of a hinged back that wont lock? Wouldnt that be the same as having no back blade at all?
RobertN, are you selling your rollover box because it is deficient in some way compared to a regular box? I'm looking at a used Bush Hog rollover. I havent tried it. Seems that you can lower the scarifiers with a lever but you cant adjust the height. I think you also flip the box with the lever. I assume the rollover allows you to cut or smooth in forward and reverse. Is that right?
YIKES! /w3tcompact/icons/shocked.gif
First time I've posted a question in a while, and I'd forgotten just how overwhelming this board can be. Thanks to all for your valuable insights. Oh, and thank you, too, Glenn, for your uh... comments. /w3tcompact/icons/laugh.gif
GlueGuy -
<font color=blue>You failed to mention whether your rear blade was locked or hinged</font color=blue>
I've failed at a lot of things, but if you read the post slowly and carefully, I did mention that it was hinged. /w3tcompact/icons/wink.gif What I did not mention is that it is not lockable.
<font color=blue>I fail to understand the usefulness of the hinged rear blade.</font color=blue>
I'm starting to share your feelings on that one, Bill. /w3tcompact/icons/crazy.gif
GlennMac -
Your comments are cynical, sarcastic and unfortunately, right on! Wish I could express myself half as well as you do. /w3tcompact/icons/wink.gif
<font color=blue>I am confused about the hinged back. Does it swing both ways?</font color=blue>
Do you? /w3tcompact/icons/laugh.gif
You set me up for that one, didn't you? /w3tcompact/icons/wink.gif Amazing that we ever exchange any real information here, like what you just posted about the Gill boxscrapers. That was downright useful. Thanks!
mdbarb -
From my extremely limited experience, I would say you need to loosen the soil more before you will get the leveling behavior you are seeking. If your box has scarifiers, go for it. Otherwise throw a tiller on there for a couple of passes. I did that to about an acre of property last month and it made all the difference in the world.
Bird -
Yeah, you and I have already had some conversation about our box blades. They are apparently almost identical except that your rear blade is fixed and mine flaps in the breeze. I can see where a fixed rear blade would give you the same effect as back-dragging the loader bucket. I wonder if the free-floating rear blade was meant to be effective only when running backwards, and just flip out of the way when going forwards.
mrolson -
As I indicated to mdbarb above, I agree with you about ripping things up before trying to level anything. I also think the rains can play an important role in packing things down. Unfortunately, I don't know if Mom will be able to do much walking at all next season, assuming she is still with us. /w3tcompact/icons/frown.gif
MChalkley -
<font color=blue>Only 50 hours of seat time? You've got more time than that on your cup...</font color=blue>
That's not fair -- my Chalkley cup (two of them, actually) stay at the property full time, while I only get up there a couple of weekends a month. BTW -- the dual magnet approach has been working out flawlessly, and with the hot spells we've had here over the last month or so, I've drained all 52 ounces of Garorade 2 or 3 times a day out there, which fer sure has saved me from a world of hurt. Thanks for the concept, buddy! /w3tcompact/icons/smile.gif
As for turning the box blade on end, I will file that idea under... well, I'll file it. Trust me. /w3tcompact/icons/wink.gif
JonLeonard -
Thanks for the info on making a real path. There are several areas on the property where it would be nice to have what you described. I don't mind the labor as long as I can find the time... and the money. /w3tcompact/icons/crazy.gif
RobertN -
Hey, Pal -- I appreciate the offer 'cuz I know you mean it. Rather than hauling that sucker back and forth, maybe it would make more sense for me to stop by for a demo sometime. I'm at least half serious here, so maybe I'll be in touch. Who know? Maybe I'm the customer you've been looking for.
StanInCalif -
A landscape rake is already on my wish list, along with a dozen or so other things I can't afford right now.
Whereabouts in Californina are you, Dude? Anywhere near me, RobertN or Rat in the northern parts? We're sort of scattered between Sacramento and Lake Tahoe.
gordon -
No, my back blade has no locking mechanism. I'm gonna have to stop talking about welding and get serious about it. My desire may overcome my lack of time and money. Where there is a will...
/ Yet Another Box Blade Question #20
Harv,
Actually, I did read it carefully, but I didn't make my statement clearly. What I should have said was whether your hinged blade was locked or free. No reply necessary, but I get it now.
That said, I now understand the purpose of the rear hinge. When the box is tipped forward (shorter top link) it will go deep. When the box is tipped backward (longer top link) it will go deeper.
This is a bit weird, as my boxblade goes plenty deep enough without the hinge. However, the fact that your rear blade can't be locked seems a serious short coming. /w3tcompact/icons/crazy.gif
The fixed rear blade and smoothing operation is very very handy and useful. If you can come up with a locking design, one of my neighbors does welding for a living and is an A #1 ACE at it. Bring it on over to the west side, and we can fix you up. /w3tcompact/icons/wink.gif
The GlueGuy
HYUNDAI HL955 WHEEL LOADER (A62129)
HYUNDAI HL955...
2021 ISUZU NPR CAB AND CHASSIS (A60736)
2021 ISUZU NPR CAB...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
2015 C.GALLEGOS PNEUMATIC TRAILER (A60736)
2015 C.GALLEGOS...
