Yellow Warning light
/ Yellow Warning light #1
Joebeck81
New Holland TN75
We have a New Holland TN75 tractor that is either a 1997 or 1998 . There is a yellow warning light that sometimes comes on when going up a hill. It is a blinking light and just started yesterday. It is a circle with an exclamation point inside with parathesis on the outside of the circle. Can you tell us what this light is for. We lost our manual in a fire in 2023. We just had a new clutch put in this tractor this past summer.
/ Yellow Warning light #2
should link you to owner's manual and shop manual
/ Yellow Warning light #3
I wonder if your DPF is getting plugged and only comes on during harder work like going up a hill. Not much info on line to look at.
/ Yellow Warning light #4
What i see is showing brake system failure. Weird, why when going up hill
/ Yellow Warning light #5
No DPF on this tractor. Too old.
The symbol is for the brake fluid reservoir indicating that the fluid is low. It is probably on the cusp and going up/down a hill is causing it to flash.
Use NH brake oil, NOT brake fluid.
/ Yellow Warning light #6
Interesting...I learned something today. Another thread on this fluid:
TN65 New Holland Brake Fluid
/ Yellow Warning light #7
Strange…i never really thought about tractors having brake cylinders, i always just thought they used gearing in transmission for brakes, and that just used transmission fluid. Never really gave it any thought
/ Yellow Warning light #8
There's a long thread about a guy replacing his master cylinders (yes, 2 of them) in here.
No DEF on these tractors. Thankfully. Computerized, but only mechanical fuel injection.
/ Yellow Warning light #9
NH are a pain. Have a TD95D. Brake fluid. Power steering reservoir. Expensive filters. Makes me glad I have more JD than NH's
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2009 Kershaw 75-G2 Sky Trim (A65579)
2009 Kershaw 75-G2...
2017 FREIGHTLINER CASCADIA  6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63689)
Magnolia Trailer...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
2024 Wolverine X2 1000 R-Spec (A62679)
2024 Wolverine X2...
