Yellow Warning light
/ Yellow Warning light #1
Joebeck81
New Holland TN75
We have a New Holland TN75 tractor that is either a 1997 or 1998 . There is a yellow warning light that sometimes comes on when going up a hill. It is a blinking light and just started yesterday. It is a circle with an exclamation point inside with parathesis on the outside of the circle. Can you tell us what this light is for. We lost our manual in a fire in 2023. We just had a new clutch put in this tractor this past summer.
/ Yellow Warning light #2
should link you to owner's manual and shop manual
/ Yellow Warning light #3
I wonder if your DPF is getting plugged and only comes on during harder work like going up a hill. Not much info on line to look at.
/ Yellow Warning light #4
What i see is showing brake system failure. Weird, why when going up hill
/ Yellow Warning light #5
No DPF on this tractor. Too old.
The symbol is for the brake fluid reservoir indicating that the fluid is low. It is probably on the cusp and going up/down a hill is causing it to flash.
Use NH brake oil, NOT brake fluid.
/ Yellow Warning light #6
Interesting...I learned something today. Another thread on this fluid:
TN65 New Holland Brake Fluid
/ Yellow Warning light #7
Strange…i never really thought about tractors having brake cylinders, i always just thought they used gearing in transmission for brakes, and that just used transmission fluid. Never really gave it any thought
/ Yellow Warning light #8
There's a long thread about a guy replacing his master cylinders (yes, 2 of them) in here.
No DEF on these tractors. Thankfully. Computerized, but only mechanical fuel injection.
/ Yellow Warning light #9
NH are a pain. Have a TD95D. Brake fluid. Power steering reservoir. Expensive filters. Makes me glad I have more JD than NH's
2023 Case IH 110C Tractor W/ Case IH L630 Loader (A64047)
2023 Case IH 110C...
Bell 1600 Gallon Nurse Trailer (A63688)
Bell 1600 Gallon...
Hardi Pull Type Sprayer (A64047)
Hardi Pull Type...
Used Landpride GR1525 Stump Grinder
Used Landpride...
SDLD25 Crawler Dumper (A64047)
SDLD25 Crawler...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
