Yardman starter???
/ Yardman starter??? #1
xgraysonx
larimore northdakota
Farmall B
Pulling apart my mower as I've figured out that the starter **** out on me.... But I'm stuck I can't get this metal plate or what not off.... Can anyone tell me how??? Pix attached
/ Yardman starter??? #2
Looks like a spanner for the nut and a large puller to remove the flywheel/ringgear
/ Yardman starter??? #3
What generally works is to back off the nut flush with end of the threads.
Then a sharp rap with a hammer most often the flywheel will simply pop of the tapered shaft end.
Not to heavy a hammer and not all that hard a blow.
You want the nut flush so as not to damage the threads.
Good luck!
/ Yardman starter??? #4
I replaced my Yardman starter last year without removing the flywheel. (19 hp Briggs) It took a lot of very short turns of the wrench on that back bolt, but it can be done. Good Luck.
HONDA Plate Compactor (A64553)
HONDA Plate...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
2000 Chevrolet Astro Cargo Van (A64194)
2000 Chevrolet...
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
10000LBS Two Post Auto Lift (A64194)
10000LBS Two Post...
2022 EZ-GO ELITE...
