Yard Rake
   / Yard Rake #1
Greg_Phillips
Western Kentuky
CaseIH Maxxum 125
I would like to build a yard rake to windrow grass clippings and other debris so that I can pick them up with a yard sweep. What I have been planning is something like what Graetz Mfg has on their website (Metal Fabrication | Custom Chains, Sprockets, Gears & More | Graetz). What I have on my mind is to use the electric clutch off a mower deck to activate the rake, but what I am unsure of is what to use as the round discs on each end. I have thought about just using some disc bladed off of an old disc, just wondering if anyone here had built one or had any ideas about building one?
   / Yard Rake
I have seen the Estate Rake once or twice but they look like they might be built a little bit on the lightweight side. We raise hay, so I have some spare hay rake tines laying around that I could use to build one more like a the Graetz, I'm just not going to use an engine. If I can use an electric clutch I will, if not I will probably use some kind of friction drive system. Any thoughts?
   / Yard Rake #4
The Graetz is ground drive off of the left wheel, I see no need for an electric clutch.
MASSAGE CHAIR (A58214)
2008 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2008 CATERPILLAR...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
PENDING SELLER CONFIRMATIONS (A59904)
PENDING SELLER...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
