Yanmar VIO 40-2 Excavator
   / Yanmar VIO 40-2 Excavator #1
dougdanger
melbourne, Victoria
Yanmar vio 40-2
Hi Guys,
I recently bought a Yanmar VIO 40-2 (2002 4t ) Excavator and i'm having trouble identifying the Diesel motor that's in it as there are no owners manual etc included .
Its the standard original motor with no mods and im just trying to find the service items and manuals ...
Cheers, Doug ..
   / Yanmar VIO 40-2 Excavator #2
Thanks Winston1 , You're a legend !!
I don't know if you can help but ....
If i run my engine at near peak power rpm it will eventually stumble and stop ! all the filters are clear and full of fuel, the only thing i can guess at is the fuel return pipe from the is VERY hot ! and maybe the fuel is vaporizing ? ... If i leave the engine to idle for a while or turn it of for a while then it runs good again (for a while and then stumbles and tries to stall again) ... if i Knock the rpm's down it will run all day with no issue but has less hydraulic power which is obviously not what i want ..
Can any body help ?
Cheers, Doug ..
   / Yanmar VIO 40-2 Excavator #4
Sure don't have an answer for you but wondering where your heat gauge is reading or does it have a warning light?
temp gauge reads fine until i run on the higher rpm and then it starts to rise ... when i back the motor off it falls again ...
Cheers, Doug ..
   / Yanmar VIO 40-2 Excavator #6
When it starts to rise does that mean it approaches over heating? Do you think your cooling system is in good condition? Outer and inner radiator tubes clean? Fan belt tight? Thermostat opening properly? Just putting this out there for consideration, probably not the cause of your problem.
Did you read over the trouble shooting section of the service or operators manual? I scanned it but didn't see anything listed with your particular problem.
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
40' CONTAINER (A51248)
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2019 Ram 5500 Dump Bed, VIN # 3C7WRNFL2KG599631 (A51572)
2019 Ram 5500 Dump...
