Yanmar torque specs
/ Yanmar torque specs #1
toytech40
Doing some work to a friends Yanmar 1100D, I need to know what the head bolt/nut torque is. Also if there is a specific sequence that will be helpful as well.
Thamk you
I will get ittonight when I get home
Found a tag on the block with 2T73 is that the model number you need? There were some nubers but they were rpm and liters.
Thank you
Anyone with a source for torque specs??
Thank you
/ Yanmar torque specs #8
The book I normally use doesn't list the model you need but here's the link to it.
http://www.aera.org/downloads/Torque3.pdf
I do have the service manuals for the Cub Yanmar tractors but they use a different engine.
What are the diameters of the head bolts?
Here's the chart for the Cub Yanmar heads.
2007 Ari-Hetra HDML-8 60,000lb Four Post Auto Lift (A66736)
2007 Ari-Hetra...
TIRE RACK WITH DIFFERENT SIZE TIRES/WHEELS (A68842)
TIRE RACK WITH...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
12 Ton Hydraulic Bottle Jack (A64557)
12 Ton Hydraulic...
2000 STERLING LT8500 SERIES WATER TRUCK (INOPERABLE) (A67714)
2000 STERLING...
DRIVE WHEEL W/ PUMP (A65054)
DRIVE WHEEL W/...
