Yanmar TDC Timing
/ Yanmar TDC Timing #1
mark777
S.E Texas
Ym1300d-1401D-1601D , 1610D & Massey Ferguson 1020
O.K. Folks...I should probably know this, but only think it's true. Are all Yanmar engines #1 cylinder at the back (flywheel side) ?
Everything I've read, worked on and seen, including a few 3 digit made for America Yanmars indicates the #1 cylinder at the rear. I have just been into a 3T75U engine on a YM1610 and everything indicates the camshaft has been timed (to the crankshaft) to the forward cylinder, #3 at TDC.
It's obvious that someone has been into the engine before me, and I'm thinking they have timed it off the wrong cylinder....it does run but poorly with no power. Am I wrong here??
Thanks for any input, Mark
/ Yanmar TDC Timing #2
You are right as far as I know.
Danny
/ Yanmar TDC Timing
Thank you Danny...I really needed to hear that :). Now I am comfortable with pulling the rocker assembly and camshaft and re-timing correctly.
Mark
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
Great Dane Van Trailer (A63689)
Great Dane Van...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2013 Hagie STS 12 Sprayer (A63111)
2013 Hagie STS 12...
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A59912)
2010 HINO 268 4X2...
