careyo63
Elite Member
- Joined
- Jan 6, 2012
- Messages
- 2,650
- Tractor
- 77 Yanmar YM2000 63 Ford 2000
Check the Adj. on the Valves and run it. The Compression is low but may come up some after some use. The fuel in the oil problem could have caused the Rings to wear and some Low Compression. Get it all cleaned out, good Oil and if it gives you Problems Try and make it till next Winter.Then when you pull the Head and check it and the valves,Guides etc. I would put some Rings in it while it's off. And Then you prob saved a good Tractor.:2cents:
