Oil & Fuel yanmar new injection pump wont pump
/ yanmar new injection pump wont pump #1
Bthieman
Ventura CA
Yanmar ym155d
Help appreciated
I had the injection pump rebuilt by a reputable shop, installed, bled, and it wont pump
I tried priming by loosening the valve holder nut on each and it pumps when this happens, but wont pump when re-tightened
Since it is a mechanical pump on a 155d, it should be simple, but it defies me
I bought it non-op, but have replaced injectors, filters, checked compression and it should go
I would love to hear it run:cool2:
Please offer suggestions
/ yanmar new injection pump wont pump #2
I know almost nothing about diesel engines ,but understand there is a "timing" factor for injection pumps .Maybe a member that knows about this will chime in.
/ yanmar new injection pump wont pump #3
Don't know what the "valve holder nut on each" is, but is it installed properly? does the rack move when you move the throttle lever? If you move the intenal plunger up against the spring, (like the cam does), does the spring restore it down.
/ yanmar new injection pump wont pump #5
I went and read the Hoye procedure. I think that is for later Yanmars.
I'll add what I read here posted by Leonard and/or Danny, two experienced dealers. This has always worked for me:
On the YM Yanmars there are two bleeder screws at the top of the filter. You will bleed the system in the order that fuel flows through - filter input bleeder screw, filter output bleeder screw, then the one down on the injector pump inlet. Wait for pure fuel to come out of each before closing it and moving on to the next. Per those two experienced dealers there is no point to opening the hard lines at the injectors if you ran out of fuel. Any air bubbles will get purged into the cylinders anyway.
I'll add do the cranking with compression released - so you don't overheat the starter - while you are forcing air out of the lines. And the throttle has to be at max to send fuel up the lines.
This has always worked for me, and with only the single of gallon of fuel in the tank that I carried out to the tractor. I haven't found a need to fill the tank full as stated in those instructions.
Bthieman, I hope you find your issue is as simple as this.
hi All
Thanks for the suggestions.
It took 2 days to bleed all the air to the new injectors, but when I connected them to the delivery lines and checked for spray i got NONE.
It seems that it is not getting enough pressure from the new injection pump to the new injectors to run
How many shims should be under the injection pump? I have 2 copper shims and it seems that if I remove one it will increase the pressure. Any one have any other suggestions?
thanks
Gpa Bill
/ yanmar new injection pump wont pump #7
As I understand it the shims are unrelated to pressure. Rather, the number of shims controls how early/late the injector pump fires.
Just to be clear -
*With the lines snug nothing comes out the injectors at any point in the revolution of the crank.
* With the lines loose, fuel dribbles out at the right time as indicated by the timing mark on the front pulley. And it fires (dribbles) once per two crank revolutions.
* You are watching cylinder #1 (nearest the flywheel) to check for fuel delivery at the timing mark.
/ yanmar new injection pump wont pump #8
You never answered these questions posed by Normde? Are you confident the governor linkage is hooked up correctly to the injector pump rack?
Hi CA
Sorry for no reply earlier
I think the primary problem was that the fuel injection pump was binding on the speed control screw (has spring detent). When I removed that screw, the fuel was easier to remove, install. AFI in Modesto, CA is recalibrating it and I await its return. compression is 380, so I expect hard starting, but since I never got fuel out of cylinder injectors, I expect it to start. Do you know if a valve job would improve compression enough, since it is not that bad?
thanks
DD
/ yanmar new injection pump wont pump #11
Check the Adj. on the Valves and run it. The Compression is low but may come up some after some use. The fuel in the oil problem could have caused the Rings to wear and some Low Compression. Get it all cleaned out, good Oil and if it gives you Problems Try and make it till next Winter.Then when you pull the Head and check it and the valves,Guides etc. I would put some Rings in it while it's off. And Then you prob saved a good Tractor.:2cents:
Thanks Carey063
It is nice to hear from someone with experience and a love for a good running machine.
This tractor is a first for this Grandpa and I am anxious to hear it run. In the 50's we always had to fix our own, so this is nostalgia.
I will check valve adjustment and change oil, and hopefully the injection pump will pump to the injectors for a good spray.
I plan to teach the grand kids how to drive a tractor and the principles of hydraulics.
Hoping for the best, and thanks again
bthieman in CA
HI CA
The injection pump should be back soon from the rebuilder after recalilbration
I am still interested in timing procedure for the 155d
does the fuel start when #1 comes up on the flywheel, or does it stop? The service manual is confusing.
thanks for the help
Gpa Bill
/ yanmar new injection pump wont pump #14
I don't have the manual here. Nor have I timed one.
What I remember reading is 1) think safety 2) crank it forward and see if the #1 (rear) injector spurts exactly at the injector timing mark, which is about 20 degrees before the TDC mark. I seem to remember TDC is at the shoulder of a counterweight cast into the front pulley but it was a long time ago I researched that, for adjusting valves at TDC.
I better defer and let somebody who knows something answer your questions. :D
/ yanmar new injection pump wont pump #15
HI CA
thanks for the help
Gpa Bill
By no means claiming to be an expert here. My reading of the instructions says the timing mark is on the crankshaft pulley. You should have a TDC mark and a 24 degrees before TDC. You are to roll to TDC, then move it back and forth in small increments, thinking it will have to be at least 24 degrees. Just at the point there is evidence of pump discharge you will take note of the position of the timing mark. Naturally, this will be when rolling clockwise looking at the front of the engine. You want it to be right on the 24 degree mark. If timing is late you need to remove shims, if early add shims. Each .0039" (.1mm) is suppose to make 1 degree difference. I doubt this is as plain as what you read in the book but thought it might help. :thumbsup:
Thanks Texas
I will follow your instructions
The service manual says to remove a valve and spring in the #1 fuel inj pumper, which is not what the rebuilder advised.
I plan to follow your instructions and not mess with the inj pump, after checking the valve clearance settings
I hope the compression comes up, but it should start if I can finally get a spray pattern at the injectors (which I have not had yet)
thanks for the advice
As another poster said
"its either the fuel or the air, it cant be anything else"
Gpa Bill
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
JOHN DEERE 6330 TRACTOR (A65057)
JOHN DEERE 6330...
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
Homemade 6'x15' Trailer (A64912)
Homemade 6'x15'...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A66734)
2019 Cub Cadet...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
