Oil & Fuel Yanmar LX4500 won't stay running
   / Yanmar LX4500 won't stay running #1
MaineRhino
Farmington Maine
Yanmar LX 4500
My 2015 Yanmar LX4500 keeps shutting off after a minute or so. I have removed and cleaned out the water/fuel separator, replaced the fuel filter and bled the system as well. It happens when using or while idling without an operator in the seat.
New diesel fuel, fuel conditioning additive as well. Kept outside in summer, in barn during winter months. 350 hours on clock, bought new in 2015.
No leaks noticed, runs great otherwise.
Is there anything I might be missing?
   / Yanmar LX4500 won't stay running #2
How exactly is the engine shutting down? Immediately, decreasing rpm's, slowly over a few seconds?
Shutdown is immediate, no stuttering or decreasing rpms. It's like someone turned off the key.
   / Yanmar LX4500 won't stay running #4
Starts back up? Not tripping any switches to make it. Sit in the seat, Depress the Clutch pedal Etc..? Trying to rule out Elec. issue or fuel?
Works best if I wait about 30 seconds or so to restart. No clutch.
No difference if operator is in seat or not.
Same results if tractor is cold or hot.
Does not act fuel starved, shuts off immediately.
   / Yanmar LX4500 won't stay running #6
Welcome to TBN. Sorry to hear that you are having issues.
Have you looked at your wiring for corrosion / rodent issues?
From afar, I would wonder about the fuel "shutoff" solenoid (that actually allows fuel in, but shuts off when the power is cut) activating because something is wrong in the circuit that supplies power.
All the best, Peter
   / Yanmar LX4500 won't stay running #7
Best guess, either a defective safety switch is shutting down the machine, or the fuel solenoid is not working properly (in order of probability).
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2015 Chevrolet Malibu Sedan (A55853)
2015 Chevrolet...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2018 KENWORTH T680 TRI AXLE DUMP TRUCK (A56138)
2018 KENWORTH T680...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
