Yanmar Injection Nozzle Testing
/ Yanmar Injection Nozzle Testing #1
jdp2011
S.E. MN
John deere 4400
I am rebuilding my injection nozzles from my JD 4400. Thought I would share some pictures. IMG_20150520_182450.jpg
The pic showing the spray pattern look close there are actually 5 spray jets. most other yanmar nozzles only have four. I beleave this was done to meet newer emission standards at the time 2001.
FYI these same injectors are used in JD models - 4200-4700, 4210-4710, 855,955,FM mowers etc pretty much any JD with a Yanmar from 1990-2000+ used this stye injector they may have different tips but that would be the only difference the body and internals would be the same. This injector is for the direct injected engines.
/ Yanmar Injection Nozzle Testing #3
Interesting, but maybe you would share a bit more about what you are doing and how/why. I don't see a pic showing a spray pattern, but do see pics with various arrangements of the nozzle (in parts as well as hooked to an apparatus). Other than that, no idea but am interested.
/ Yanmar Injection Nozzle Testing #4
I've got that same pop tester. I would think (unless your hours are way high) the nozzles just need cleaning on such a new machine. I use a toothpick in a drill with carb cleaner. If they're bad though and after a good cleaning they don't spray or don't pop at the rated pressure, I just buy new nozzles and test them in your existing injector housings. You might have to look up a ND or Hatzan cross reference to get a good price. I pay $15-$22 a piece at finditparts.com
To clarify I am replacing the injector tips on my current injectors, Setting the pop off pressure and check for chatter and spray pattern. I refer to this as rebuilding the injector.
The first photo in the attachment box shows the spray pattern- very difficult to get the timing right with the flash and when the injector pops to get a clear photo of the spray pattern
I will respectfully disagree with you. I have seen these yanmars with as low of 200 hrs- and one or more of the injector nozzles ether not spray correct or partially plugged up or no chatter sound.
Idling these motors and not putting them under a good load to keep them cleared out cause plugged up injectors.
I do have cleaning wires for the tips but most of the time they have to be replaced.
2006 Isuzu NPR 16FT Box Truck (A66736)
2006 Isuzu NPR...
UNKNOWN  TRIAXLE LOWBOY TRAILER (A67714)
UNKNOWN TRIAXLE...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
2016 Nissan Frontier Crew Cab Pickup Truck (A66736)
2016 Nissan...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
2017 KENWORTH T880 (A67714)
2017 KENWORTH T880...
