Yanmar head gasket
/ Yanmar head gasket #22
Default Re: Yanmar head gasket
If you can't find an engine model number we might be able to help with a bore diameter and distance between cylinders.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Yanmar Tractor Parts
Probably not a Tractor HG. 1.5 mm across the Cylinder is major difference in Circumference. I Measured the distance of the two in between the Cylinders using the Pics. and 4mm new and 8mm on the old. Could be a JD Hg.? If that is the correct New! HG. I have a good guess which one is the 35.00$ one.
/ Yanmar head gasket #23
Is this just some random Yanmar engine on a genset or a ditch pump that has been beat on for 30 years??? To not have a piece of equiptment to pin it too and to not have an engine ID tag/plate left on it, is just strange?
I still dont understand how you cant spot the ID tag on an engine this small??? IF its greasy wipe the flat surfaces of the lower block down. Maybe get some numbers off the head?
/ Yanmar head gasket #24
Something tells me it maybe a VN'er and a good way to hide the Mixed Matched parts. Head/Eng.block is to remove the ID. Tags. That's beginning to sound more of the issue. If they tried to remove the Stamped Numbers on the Tag would be very difficult or nearly impossible and not tell it.
/ Yanmar head gasket #26
Could be but IMO. Aaron answered his question with what he needed to do. And he probably didn't like what he found out!!! And if I'm right I sure wouldn't be Posting it that I paid good money for a POS. VN'er. :fiery:
/ Yanmar head gasket #27
yea Aaron told him with measurements he could tell him or get him close. Its just very strange?
the only thing i see making sense is what you said carey, maybe even your sugestion Cali!! haha
But i think in my mind the only thing that makes sense is that he has some super old and or rigged/neglected possibly home made something...ditchpump maybe that he found on a farm or bought at auction or CL and he knows its a yanmar engine but its connected to something like the pump and there is no way in his mind to identify the motor from the application cause he does not know the rest of the contraptions maker, its homemade from many parts, all the paint or id tags are gone??? But it still would take a concious effort to remove the id tag off a yanmar. And i still dont see how youcan miss an intact id tag. UNLESS it was leaking oil and slobberring fuel so bad that dirt is just caked all in the oil mess and it has 1/4" of grime on it and he just hasent wiped it clean?
/ Yanmar head gasket #28
FWIW... For some reason my antivirus (Avast) will not let me go back to page 1 or 2 of this thread. It says that a virus tries to load ('Gzip' or something). I thought that was strange so I tried it at home - same results. Is anyone else noticing anything strange on the first two pages? All other threads here load just fine.
/ Yanmar head gasket #30
yep i could load the first pages and also the picture fine? Maybe my work PC is now virus infected?? haha. Seriously i think were pretty protected around here though.
/ Yanmar head gasket #31
Works fine for me, but has anyone noticed that this guy has only posted twice but has a full 3 page thread?:confused3:
/ Yanmar head gasket #32
yep!! Maybe he just ordered the first gasket someone offered up?
Maybe he thinks were trashing him? I think we seriously would all like to help but need a bit more info. Like walking into Orileys and telling them you need a head gasket and it being one with 4 cyls. and all you tell them is its a ford. They could probably figure it out but may take awhile to know if it came from a v8 or a 4cyl and a year etc??
/ Yanmar head gasket #33
No problems noted here. But I'm running AdBlockPlus. Maybe that Gzip is in one of the ads surrounding the page?
/ Yanmar head gasket #34
I had a few problems this morning that was corrected. It was on a new laptop that's only 4months old. It's done it before and a lot worse that I doubt a Virus could cause. No alerts from my MacAfee either.
/ Yanmar head gasket #35
Wow! McAfee just stopped a IP. address and it was in Red. High risk! from Europe it looked to Germany. Wasn't even logged in yet. Never seen that before.
/ Yanmar head gasket #36
Ghostery.com tends to be more advanced for surfing forums. Over 40-million+ people us it.
HEIN-WERNER 57 SERIES 2 BUMPER JACK (A65643)
HEIN-WERNER 57...
more info coming soon! (A61569)
more info coming...
KOMATSU FG25T-12 WAREHOUSE FORKLIFT (A64276)
KOMATSU FG25T-12...
CASE 588H ROUGH TERRAIN FORKLIFT (A64276)
CASE 588H ROUGH...
John Deere 15' PT Batwing Mower (A64126)
John Deere 15' PT...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
