Yanmar Frame Paint
/ Yanmar Frame Paint #1
jimstractors
Pearblossom CA
Iseki, John Deere
Any one have an exact or very close paint to match the original greenish frame paint? Someone posted Rustoleum Verde Green, but I checked 3 different Home Depot's and they don't carry it. Any suggestions?
/ Yanmar Frame Paint #3
Texas Tractors,
That is an exact match on mine. Rust-Oleum Spruce Green at Walmart
/ Yanmar Frame Paint #4
If you have A Lowes store near you,they might be able to match it if you can take a paint chip with you.That's where the paint I used on my 1610 came from.Any good paint store could probably help you. Good Luck....
caveman
/ Yanmar Frame Paint #5
I went to my local Ace hardware store. They scanned it. They mixed it in an anti rust enamel. It covers well and matches very well. At less than $6 it is a bargain. The other option I tried was to have a local automotive store scan and mix it in a 3 part poly than matched exactly, BUT cost was $45 a quart.
/ Yanmar Frame Paint #6
Jim,
Try the Rustoleum #7737 Spruce Green, it blends well and I can't tell the difference from the original color on the tractor. It will take awhile to dry though. It is a satin finish and I don't know if you could get a closer color match in a rattle can! I got mine at walmat and I believe that it is a normal stocked item at California walmarts.
For the Red if doing a complete repaint of the sheet metal, I used Krylon Banner Red and it looks real sharp. This paint drys really fast and smooths out real well which makes a rattle can job much easier.
Thanks for the info. I will pick up some Spruce Green. I was looking on CornerHardware.com and they carry over 200 kinds of rustoleum. General info: I noticed that they have a Rustoleum John Deere Green and John Deere Yellow. They claim that these are official factory paints.
UNUSED (2) 3" HYD CYLINDERS (A62130)
UNUSED (2) 3" HYD...
2017 BX2680 Sub Compact Utility Tractor (A63118)
2017 BX2680 Sub...
John Deere 7230 (A62180)
John Deere 7230...
iDrive TDS-2010H...
2015 MACK CXU613 T/A 6X4 MID ROOF TRUCK TRACTOR (A59910)
2015 MACK CXU613...
BUNDLE OF APRROX (35) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
