Yanmar for snowplowing....How big?
   / Yanmar for snowplowing....How big? #1
RockyMtn
I want a 4wd Yanmar to clear snow from my 150 foot gravel driveway. Snows are frequently one to two feet deep at my elevation. Any thoughts about how big a tractor I need? Other uses (barn cleaning, mowing), would be best done on a small tractor. Thanks for your help.
   / Yanmar for snowplowing....How big? #2
Mate,
I use a YM2210D with 5 ft hydraulic blade mounted on the front of the tractor. I have about 450 ft of gravel driveway to look after.
Thanks for your input. Would a smaller tractor work for what you do? How about a rear blade?
   / Yanmar for snowplowing....How big? #4
We had 5-6 in of heavy wet snow fall here in VA on Thursday that I used my 1500D to clear using a 5' rear scraper. I used the blade facing forwards, I have seen some using it facing back and driving the tractor in reverse. Either way you are looking back all the time. Took me about 2 hours to do 300 or so yards of drive way. If you get frequent snow then something on the front would be the way to go. Also models with shuttleshift would probably be useful. If you are going to let 2 feet pile up before plowing then you are going to have to get something with a big enough blade and the 1500D would most likely not handle it.
VT
   / Yanmar for snowplowing....How big? #5
Although I don't have any experience with a blade, I don't think you'd have a problem with even a very small Yanmar tractor especially if it's 4wd. My Yanmar is smaller than those mentioned so far and it does fine on my 65' two lane driveway. I use the FEL to cleanup anything 4" and less and the rear blower for heavier snowfalls. It's a YM155D and my driveway is fairly flat and paved. In my area we average about 75-90 inches of snow a year.
Thanks for very helpful responses! Does the snowblower scrape the ground or is it possible to hold it above the surface to avoid picking up gravel?
   / Yanmar for snowplowing....How big? #7
In my case, there are some times I wish it would scrape more for when I clear the driveway after having driven on it with the car. The FEL helps with getting down to pavement if I really want to. If you have a gravel drive, and want to leave a layer of snow, I think you'd have good luck adjusting the toplink which has the effect (at least on my model blower) of rocking the scraping edge up and riding more on the skid shoes.
   / Yanmar for snowplowing....How big? #8
Wow, that blower looks neat! Now how am I going to justify buying one to my wife??? :D
   / Yanmar for snowplowing....How big? #9
Well, I've only plowed with it one time (I've owned this tractor 1 week). But I'd say for the quantity of snow you're moving, you'd want a blower if you needed a lighter/smaller tractor, or a heavier/larger tractor if you preferred a plow. I have a similar length driveway to yours, but around here we only get snow in 2-8" increments. Swedish' Fish's setup looks appropriate to your needs!
Here's me yesterday,
   / Yanmar for snowplowing....How big? #10
Hand her the shovel next time it snows!! :)
2022 Spartan RZHD Zero Turn Mower (A53117)
2022 Spartan RZHD...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2017 PJ Bumper Pull Equipment Trailer (A53117)
2017 PJ Bumper...
2016 Komatsu PC210 LC-11 Excavator (A53117)
2016 Komatsu PC210...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
