Yanmar F17D thermostat
   / Yanmar F17D thermostat #1
GeoffDeering
British Columbia, Canada
Yanmar f17d
Does anybody know if there is a North American equivalent for the thermostat used in a Yanmar F17D? Maybe a NAPA parts number or something?
I suspect mine is either stuck open or missing as the gauge does not rise ( it works) and the water from the thermostat cover to the radiator gets hot soon after starting. I have read that a lot of Japanese farmers remove the thermostats, but can't help feeling that it would be better for the engine if it ran at the designed temperature.
Thanks
Geoff
   / Yanmar F17D thermostat #2
Here is the info off the John Deere Website:
Yanmar part #:129155-49800
John Deere Part # M801088 Thermostat 16.69 USD
   / Yanmar F17D thermostat #4
Jim,
This is an interesting information. I checked the JD site and don't understand how to find it. Does this mean that you know the JD equivalent of the F17D engine ? If yes could you explain me where you found the information on the site.
Thank you for your answer,
Phil
   / Yanmar F17D thermostat #6
Jim,
Thank you very much for this information.
Phil
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
SOFTBALL & BASEBALL HITTING & CATCHING GEAR (A58374)
SOFTBALL &...
2025 SF60 60in Hydraulic Forks and Frame Skid Steer Attachment (A56857)
2025 SF60 60in...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
2017 Ford F-550 Cab and Chassis (A56858)
2017 Ford F-550...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
