Yanmar F17D thermostat
   / Yanmar F17D thermostat #1
GeoffDeering
British Columbia, Canada
Yanmar f17d
Does anybody know if there is a North American equivalent for the thermostat used in a Yanmar F17D? Maybe a NAPA parts number or something?
I suspect mine is either stuck open or missing as the gauge does not rise ( it works) and the water from the thermostat cover to the radiator gets hot soon after starting. I have read that a lot of Japanese farmers remove the thermostats, but can't help feeling that it would be better for the engine if it ran at the designed temperature.
Thanks
Geoff
   / Yanmar F17D thermostat #2
Here is the info off the John Deere Website:
Yanmar part #:129155-49800
John Deere Part # M801088 Thermostat 16.69 USD
   / Yanmar F17D thermostat #4
Jim,
This is an interesting information. I checked the JD site and don't understand how to find it. Does this mean that you know the JD equivalent of the F17D engine ? If yes could you explain me where you found the information on the site.
Thank you for your answer,
Phil
   / Yanmar F17D thermostat #6
Jim,
Thank you very much for this information.
Phil
LOT OF CHAINS (A58374)
2007 STERLING TRUCK L9500 CHEMICAL TRANSPORT TRUCK (A58214)
2007 STERLING...
New Landhonor Heavy Duty Plate Compactor (A59000)
New Landhonor...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
VERMEER FEED ROLLER (A58214)
VERMEER FEED...
