Yanmar engine info
/ Yanmar engine info #1
webn237
Monroe WI
kubota
Hey guys!
I was wondering if anyone has a book or know where I can get a book for the 3 cylinder Yanmar from a JD F1145? Im getting the engine from one and would like to rebuild it. I found the spec sheet for the tractor but not the engine.
Any info would be great!
Thanks!
/ Yanmar engine info #2
Good question. The F1145 is a front mower unit I believe. I don't think Hoye has any information on this, but maybe try your local John Deere dealer? :confused3:
/ Yanmar engine info #3
There is a listing on ebay for some F1145 engine parts that says it is a 3TNE78 but some listings also say 3TN75. Maybe it had 2 possible engines? The bore diameter should tell you which it has (78mm or 75mm).
/ Yanmar engine info #4
John Deere Parts Catalog
It looks like both the 75mm bore and 78mm bore engines were used in those machines. Hoye has service manuals advertised for certain tractors that may contain engine rebuild information for similar or interchangeable engines.
/ Yanmar engine info #5
284 International welcome home! We haven't seen you post here for a while. Anything new?
/ Yanmar engine info #6
Thank you! For better or worse there is not much new; I still lurk about though!
/ Yanmar engine info #7
Were entering our slow period I see. Not as many new posts or discussions as the summer mowing and project season is coming to a close.
/ Yanmar engine info #8
Hey guys!
Thanks!
Here is a picture of the engine tag.View attachment 583433
Is this the one being converted to the transport and needing to upgrade to the turbo too? :) Sorry, I've been on a few different forums seeing your threads. Keep up the work. It would be cool to see how all this turns out.
Yes this is the one that needs the turbo lol. Thanks its going to be sweet when its done
/ Yanmar engine info #11
Hey guys!
Thanks!
Found this on the Manuals Deere site ...
Operating
Introduction
Owner operator's manual includes detail operating instructions, maintenance
& service interval instructions, safety, and other information for your John Deere
equipment.
John Deere Operator Manual | Parts & Services | John Deere US
Equipment serial number ranges are parentheses.
F1145 Front Mower (Attachment) ATTACHMENTS (-)
F1145 Front Mower (CTMS) CTMS (-)
F1145 Front Mower (Euro) BASE UNIT (140001-) European , Yanmar 3TNE78A-JFM Diesel Engine
F1145 Front Mower (Exp) BASE UNIT (010001-140000) Export , Yanmar 3TN75RJ Diesel Engine
F1145 Front Mower (Exp) BASE UNIT (140001-) Export , Yanmar 3TNE78A Diesel Engine
F1145 Front Mower (N.A.) BASE UNIT (010001-140000) North American , Yanmar 3TN75RJ Diesel Engine
F1145 Front Mower (N.A.) BASE UNIT (140001-) North American , Yanmar 3TNE78A-JFM Diesel Engine
Your S/N is 012588 in your supplied image, so your Yanmar engine is 3TN75RJ
The J at the end of the engine type means, Yanmar made this per John Deere specifications in NA.
The engine is also used in a regular Yanmar tractor made for JD as a JD-855 CUT tractor. :)
TractorData.com John Deere 855 tractor engine information
Powertrain for John Deere 855
Engine type: Yanmar 3TN75RJ Cylinders: 3 Displacement: 60.7 ci [1.0 L]
Bore/Stroke: 2.95x2.95 inches [75 x 75 mm] Compression: 17.8:1 RPM: 3200
Gross Power: n/a Torque: n/a Torque RPM: n/a
Net Power: n/a PTO: n/a Drawbar: n/a
Rear PTO: independent Rear RPM: 540 Clutch: n/a
Cooling: liquid Coolant: 4 qts [3.8 L] Air Cleaner Type: dry element
Oil Capacity: 3.8 qts [3.6 L] Oil Change: n/a Fuel: diesel
Transmission Type: hydrostatic Gears: infinite (2-range) forward and reverse
The F1145 and the JD-855 have the same engine.
The base engine of 3TN75 comes in several configurations via Yanmar. Even the engine rebuilt kits work interchangeably with this engine.
Applications Suitable For :
WADO SANGYO CO., LTD. Y. Ag. Equip YSR2100 Snow Blower 3TN75L-RSR
Yanmar Agricultural Equipment YSR1710H, YSR2100 Snow Blower 3TN75-RSR(*)
Yanmar Agricultural Equipment F17 Tractor 3TN75-UA
Yanmar Agricultural Equipment FX17 Tractor 3TN75-UAP
Yanmar Agricultural Equipment FX16 Tractor 3TN75-UB
Yanmar Agricultural Equipment FX16 Tractor 3TN75-UBP
Yanmar Agricultural Equipment (Kinomoto) FX175DPT Tractor 3TN75-RNGR
Yanmar Agricultural Equipment (Kinomoto) F175, FX175 Tractor 3TN75-UNA
Yanmar Agricultural Equipment (Kinomoto) F175, FX175 Tractor 3TN75-UNAP
Yanmar Agricultural Equipment (Nagahama) FX17 Tractor 3TN75-UAPGR
Yanmar Agricultural Equipment (SF) F-7D Tractor 3TN75-RN2
Yanmar Agricultural Equipment (SF) F165 Tractor 3TN75-UN
Yanmar Agricultural Equipment (SF) FX165 Tractor 3TN75-UNB
Yanmar Agricultural Equipment (SF) FX165 Tractor 3TN75-UNBP
Yanmar Agricultural Equipment (SK) CA21D Combine 3TN75-RAC
Yanmar Agricultural Equipment (SK) CA210 UFO Combine 3TN75-RA1C
Yanmar Agricultural Equipment (SK) CA210 Combine 3TN75-RA2C
Yanmar Agricultural Equipment (SK) CA220 Combine 3TN75-RNC
Yanmar Construction Equipment (SF) YB221, B22.EP Excavator 3TN75L-RB
Yanmar Construction Equipment (SF) B22-2 Excavator 3TN75L-RB1
Yanmar Construction Equipment (SF) B25-2 Excavator 3TN75L-RB2
Yanmar Construction Equipment (SF) YFW20DW,YFW25R Carrier 3TN75L-RFW
Yanmar Construction Equipment (SF) HG20 Carrier 3TN75L-RYC
Yanmar Domestic Japan, General Generator Spec 3TN75E-G1
Yanmar Domestic Japan, General High Speed Generator Spec 3TN75E-G2
Yanmar Nagahama Plant YEG18H(-P,-B) Generator Set 3TN75E-RGYH
So, there should be some sort of parts manual around ...
Knowing this engine type is used in the F & FX CUT tractors, Fredrick's has parts!
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2025 SB05 Hydraulic Breaker Mini Excavator Attachment (A59228)
2025 SB05...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
