yanmar charging
/ yanmar charging #1
u122423
ohio
Kioti
I have a takeuchi mini excavator with a Yanmar (3TNA72E) motor. It currently has a generator with a regulator, I would like to switch to a 1 wire alt. has anyone done this? If so what alt. did you use? any help would be great.
Thanks
/ yanmar charging #2
Not much help here but curious. I am thinking maybe you have a dynamo and a rectifier that converts to dc voltage. I converted my old Yanmar tractor from a dynamo to an alternator. Very hard to find room for it even though I used a very small alternator. This one. denso mini alternator 8162 | eBay
/ yanmar charging #3
I used the same alternator on both my fx-28's. they fit perfect only mode was a 1/2" spacer on the top mount. Works great.
/ yanmar charging
Thanks for the info, I bought one yesterday at a local alt. shop and I,m pretty sure that's the one I bought, the denso mini. Its going to be nice to get rid of alot of my cobbled up wiring. Now to get the rear cover off to get at the engine! Thanks again.
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2016 Freightliner 108SD (A64194)
2016 Freightliner...
1999 Coachman Catalina RV/Camper VIN # 3FCMF53S2XJA29020 (A65563)
1999 Coachman...
2003 Odyssey Lextra 2502 Pontoon w/ 2009 Bagg Boat Trailer (A62613)
2003 Odyssey...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
