Yanmar BM480SB-E Mower Deck-Blades?
   / Yanmar BM480SB-E Mower Deck-Blades? #1
odiebob
Illinois
JD 4400 w/430 loader YM146 with mower
Hello All,
I'm STILL trying to find blades for BM480SB-E Mower Deck
currently under a YM-146 tractor.
Any help would be greatly appreciated
Bob
   / Yanmar BM480SB-E Mower Deck-Blades? #2
Hello All,
Bob
Do you have any images of the old blades?
   / Yanmar BM480SB-E Mower Deck-Blades? #3
Hello All,
Bob
Do you have a part number from the manual, or off the blade?
All the best, Peter
   / Yanmar BM480SB-E Mower Deck-Blades? #4
length, width, thickness, offset, hole size?
   / Yanmar BM480SB-E Mower Deck-Blades? #5
A web search clue . . .
Blade SET (3) - YRM48, BM480 - national back order.
Is the YRM48 then using the same sets of blades?
If the Y is taken off, the model becomes the RM48, the Woods mower.
   / Yanmar BM480SB-E Mower Deck-Blades? #6
I don't know if it is the right part number, but it might be equivalent to 12170kt (Woods blade kit for the RM48). If so,
(There's a photo here; Set/3 blades for Woods some RM48 rear mount grooming/finish/belly mower 12170KT | eBay)
Does these look close? There seem to be a couple of threads on TBN that mention that the RM48 mower comes in CW and CCW versions, with matching blades, which would make me rather careful when ordering these if you aren't buying the blades from Yanmar...
All the best,
Peter
   / Yanmar BM480SB-E Mower Deck-Blades? #7
Hello All,
Bob
I have the BM480SB-E blades in stock.
I will send you a private message that you can go to in the upper right hand corner of TBN site.
Thank you guys!! I will get back to you all as soon as I can. Working lots of hours.
((Update)) I found a receipt from a place my dad bought Yanmar parts. Called them and they supposedly have a set of 3 blades for this deck, lucky day. Gonna pick them up tomorrow and see if they fit and are correct. Problem is the deck did not have blades on it but found some blades he had laying around but he had multiple mowers before. Wheel horse and Yanmar. So I really want confirmation from a dealer that is it correct for deck.
So I hope these are correct and fit if not I can return them. Will update everyone then. Thank you all for your help You guys are great!!
   / Yanmar BM480SB-E Mower Deck-Blades? #10
Good luck!
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
KBH Tender (A61307)
KBH Tender (A61307)
2014 Ford Focus Sedan (A59231)
2014 Ford Focus...
