Yanmar B7 Excavator
   / Yanmar B7 Excavator #1
sos1
Bronze Member
My son bought a B7 and found the hydraulic motor for the cooling blower doesn't work. It appears to be connected to a hydraulic control valve with what appears to be an electric solenoid attached to the control valve. Does anyone have any info that might help in diagnosing the problem and fixing it?
Thanks!
   / Yanmar B7 Excavator #2
I don't own a B7 but do you think that the fan might be thermostatically controlled? Maybe that "solenoid" is a temp sensor. Try jumping it an see if the fan comes on. Just a thought from me. Good Luck
SimS
We had that thought and did just as you suggested. The solenoid does activate, but the motor doesn't run. I thought the valve might be stuck
and not opening. We're trying to find a service manual.
   / Yanmar B7 Excavator #4
Have you tried a Yanmar dealer?
Dominion Equipment deals in gray market machines. I'm going to
contact them.
Yes, Serial # 00501B
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2011 NOV ROLLIGON DOUBLE PUMPER (A53843)
2011 NOV ROLLIGON...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
2020 Isuzu NPR Heil 8RLDB 8CuYd Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
