Yanmar AF22-Tachometer failing
   / Yanmar AF22-Tachometer failing #1
EuroYanmar
Somewhere
Tractormatic
Good morning (evening) everybody,
The tachometer of my Yanmar AF22 stopped working suddenly when I was bushhogging.
Does anybody on the board knows if it is a mechanic (with cable) or electronic one (with sensor) ?
How to check this point ?
Have you heard of Yanmar tractors using electronic tachometers ?
Thanks for your help.
Here is the tractor (not mine but the same model) :
http://www.tractorbynet.com/forums/...4-pictures-yanmar-af22-610191-yanmar-af22.jpg
Phil
   / Yanmar AF22-Tachometer failing #2
Haven't seen you on in some time . I would look on the back side of the tach. & see if there is a cable attatched & follow it to where it connects to the engine. It shouldn't be hard to tell if it's a mechanical or electrical .
Ken and Buck,
Thanks for answers.
So it's a cable unit. It's Better as I can easily fix the problem. I don't know where I could have found a sensor for an electronic one.
Yes, Ken, I've been out of France for a while with few Internet facilities there.
Buck, what are exactly these models you own :Shibaura V70, Hinomoto JF-1, Yanmar RS30, Yanmar F7H ?
Did you post some pictures of them in the past ?
Phil
   / Yanmar AF22-Tachometer failing #5
I just replaced my cable for the tach/hour meter and it all works great now. Very simple task....
GCP,
I had a look last sunday on the tach of my AF22. It's a cable unit just as I've been told by Buck and Kenmac.
But it seems that to remove it I need to take out the radiator.
Just a question : Where exactly your cable was broken ? Near the instrument pannel, near the engine or maybe somewhere else ?
Did you replace it by an original part or a substitute ?
Thanks for the answer.
Phil
   / Yanmar AF22-Tachometer failing #7
EuroYanmar said:
GCP,
Phil
Phil, I think gcp has a YM2000.
Danny
Danny,
I misunderstood.
Anyway his answer will be interesting.
Thanks Danny.
Phil
   / Yanmar AF22-Tachometer failing #9
EuroYanmar, 1danny is right, mine is a YM2000. My cable was broken on the engine side so all I had to do is remove the old and install the new. I was worried about the old piece being still in there and did bring a magnet to fish it out but it was not anywhere I could get to it. If it's still in there it's causing no problems with rendering the new cable non-functional.
Hope this helps,
gcp
GCP,
Thanks for your answer.
Phil
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
2018 JLG 10054 TELESCOPIC FORKLIFT (A51406)
2018 JLG 10054...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
