Yanmar AF22-Tachometer failing
   / Yanmar AF22-Tachometer failing #1
EuroYanmar
Somewhere
Tractormatic
Good morning (evening) everybody,
The tachometer of my Yanmar AF22 stopped working suddenly when I was bushhogging.
Does anybody on the board knows if it is a mechanic (with cable) or electronic one (with sensor) ?
How to check this point ?
Have you heard of Yanmar tractors using electronic tachometers ?
Thanks for your help.
Here is the tractor (not mine but the same model) :
http://www.tractorbynet.com/forums/...4-pictures-yanmar-af22-610191-yanmar-af22.jpg
Phil
   / Yanmar AF22-Tachometer failing #2
Haven't seen you on in some time . I would look on the back side of the tach. & see if there is a cable attatched & follow it to where it connects to the engine. It shouldn't be hard to tell if it's a mechanical or electrical .
Ken and Buck,
Thanks for answers.
So it's a cable unit. It's Better as I can easily fix the problem. I don't know where I could have found a sensor for an electronic one.
Yes, Ken, I've been out of France for a while with few Internet facilities there.
Buck, what are exactly these models you own :Shibaura V70, Hinomoto JF-1, Yanmar RS30, Yanmar F7H ?
Did you post some pictures of them in the past ?
Phil
   / Yanmar AF22-Tachometer failing #5
I just replaced my cable for the tach/hour meter and it all works great now. Very simple task....
GCP,
I had a look last sunday on the tach of my AF22. It's a cable unit just as I've been told by Buck and Kenmac.
But it seems that to remove it I need to take out the radiator.
Just a question : Where exactly your cable was broken ? Near the instrument pannel, near the engine or maybe somewhere else ?
Did you replace it by an original part or a substitute ?
Thanks for the answer.
Phil
   / Yanmar AF22-Tachometer failing #7
EuroYanmar said:
GCP,
Phil
Phil, I think gcp has a YM2000.
Danny
Danny,
I misunderstood.
Anyway his answer will be interesting.
Thanks Danny.
Phil
   / Yanmar AF22-Tachometer failing #9
EuroYanmar, 1danny is right, mine is a YM2000. My cable was broken on the engine side so all I had to do is remove the old and install the new. I was worried about the old piece being still in there and did bring a magnet to fish it out but it was not anywhere I could get to it. If it's still in there it's causing no problems with rendering the new cable non-functional.
Hope this helps,
gcp
GCP,
Thanks for your answer.
Phil
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
