Yanmar 4WD Tractors
/ Yanmar 4WD Tractors #21
Man thats a good pic. Looks like the 3810D. That may be more in the size of what I'm looking for. But if the parts availability isn't as good as the 3110D, then...(??)
Do you think the 3110D or the 3810D equipped with a FEL will "pull" as much as my 2wd Massey 231?
Is the tractor in the pic for sale?
Travis
The YM3810D is more or less a YM3110D with a turbo. Don't know much about Massey. No, that pic is several years old.
Danny
/ Yanmar 4WD Tractors #22
Travis
Travis,
I have a 3810D and its very capable of handling 6-7' attachments you will like it if you can even find one they are kind of scarce.
Fact that pic is nearly my exact same setup with a Koyker 160 loader and all and I cant think of anything I dont like about either, and btw it will pull an unbelievable load seriously and it is a miser on fuel I can run it hard all day on a half tank.
I am amazed at what it will do, the powershift trans is just the best thing whatever you get keep that in mind! hth
Steve
Thanks Steve. Do you have any pictures of your tractor you could post on here?
Travis
/ Yanmar 4WD Tractors #24
Travis,
Here is a couple pics I took doing some work at my garden plot last year. I had a old Ford 2 bottom plow attached and it was buried in new dirt and it wasn't short of power or traction I was impressed to say the least.
Ask any questions you want I will answer all I am capable of, I am new to the compact tractor world however I went from a 1952 Massey Harris 22K (22hp) row crop to this Yanmar and the difference is remarkable to say the least. :)
Steve
/ Yanmar 4WD Tractors #25
What models has the shuttle shift up by the steering column? I think those would be the ones I'm interested in- if they have good parts availability.
Travis
The 20 series are powershift and have the gearshift on the strg column and a little more sheet metal around the floor board area and I believe have gages, 10 has powershift with a floor shift and 0x are gear drives from what I know someone else may correct me. hth
Steve
Sure is a fine tractor you got there! Thanks for the pics and info. For me, I'm thinking either the 3810D or the 3220D. I think I'd like the powershift on the steering column. Plus, from the specs, the 3220D weighs alittle more than the 3810D also...
Travis
/ Yanmar 4WD Tractors #27
Welcome Travis and thanks for giving me the opportunity to show my tractor!
Good luck on your search sounds like you are working on a good plan post pics!
Btw I had debated on a 3110 or 3220 also and the absolute only reason I picked the 3810 is the turbo dumb reason I know but I am an old hot rodder old habits are hard to change ;), As far as the extra hp I doubt I would have ever noticed or needed it with either of the other 2 fwtw.
Steve
/ Yanmar 4WD Tractors #28
Can you post a pic of how the turbos on the engine?
What turbo is it?
How hard would it be to put one on a 3110?
