yanmar 4300d rebuild
   / yanmar 4300d rebuild #1
jamesinms
The 3t90t engine just got a new turbo, we put a garret t3/t4 on it. It ran fine for 10 hours now it seems to flood out and has blown small aluminum peices from the exhaust. I took the turbo off it was not damaged and tractor ran the same without it. does this sound like a rebuild required and where can i get a kit
   / yanmar 4300d rebuild #2
I can probably supply you with parts, but I don't know if you need a rebuild. The only aluminum that I would know of would be from a piston getting to hot & melting. It is a good idea to install a pyrometer if one is putting a different turbo than the OEM one, unless you are sure it is a compareable replacement. I'd recommend pulling the head & inspecting the pistons.
I will pull the head and check. I checked the valves and the exhaust side of the third cylinder didn't seem to move freely. I checked the specs on the turbo before we installed it and installed a waste gate and we did check the boost pressure to make sure we didn't create a runaway flame thrower. Thanks for your info.
   / yanmar 4300d rebuild #4
Finally someone else with the same tractor. Old as this post is it might be the same one LOL.
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A51572)
1998 Dorsey...
John Deere S780 Combine (A53342)
John Deere S780...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2021 JOHN DEERE 8R 370 LOT NUMBER 188 (A53084)
2021 JOHN DEERE 8R...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
