yanmar 4300d rebuild
   / yanmar 4300d rebuild #1
jamesinms
The 3t90t engine just got a new turbo, we put a garret t3/t4 on it. It ran fine for 10 hours now it seems to flood out and has blown small aluminum peices from the exhaust. I took the turbo off it was not damaged and tractor ran the same without it. does this sound like a rebuild required and where can i get a kit
   / yanmar 4300d rebuild #2
I can probably supply you with parts, but I don't know if you need a rebuild. The only aluminum that I would know of would be from a piston getting to hot & melting. It is a good idea to install a pyrometer if one is putting a different turbo than the OEM one, unless you are sure it is a compareable replacement. I'd recommend pulling the head & inspecting the pistons.
I will pull the head and check. I checked the valves and the exhaust side of the third cylinder didn't seem to move freely. I checked the specs on the turbo before we installed it and installed a waste gate and we did check the boost pressure to make sure we didn't create a runaway flame thrower. Thanks for your info.
   / yanmar 4300d rebuild #4
Finally someone else with the same tractor. Old as this post is it might be the same one LOL.
24in Tractor Backhoe Bucket BT4555 (A53472)
24in Tractor...
2019 Freightliner M2 106 Sweeper Truck, VIN # 1FVACXFC1KHKF6139 (A51572)
2019 Freightliner...
2019 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2019 FREIGHTLINER...
New/Unused 13ft x 20ft Single Garage Metal Shed (A51573)
New/Unused 13ft x...
Mccormick Hammer Mill (A51573)
Mccormick Hammer...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
