Yanmar 336D Power Steering Question
/ Yanmar 336D Power Steering Question #1
S Putnik
Bronze Member
Portland, OR
Yanmar YM336D
Hi All,
A new-to-me Yanmar 336D was delivered to my house today. In the few minutes that I've had to play with it I've noticed that the power steering is not so powerful as I imagined it would be. It's really quite difficult to turn the wheel when the tractor is not in motion. Not having any experience with with this make and model I have no sense for what is normal and what is the result of damage or excessive wear.
Does anyone have any thoughts on this? Any info would be much appreciated.
/ Yanmar 336D Power Steering Question #2
As usual, I have thoughts. :D My ym2002d has the factory gearbox style power steeriing. I also have a front end loader. Setting on normal hard surface without any front end load I can spin the steering wheel. With a loader full of dirt I don't try to turn it without moving. Just saying the load you have on the front end and the surface you are turning on plays a big part. Looking at the ym336 parts manual I believe you have the same setup I have. Don't know whether I answered your question or not.
Thanks Winston. You came close. On dry pavement with an empty loader my steering is hard to turn,and very hard to turn toward the extremes. The difference between your experience and mine might be that the 336 is a heavier machine using the same gearbox.
If this is just the way it is, I'm dissapointed in that I really hoped my next tractor would have power steering to reduce the strain on my shoulders. On the other hand, if it's working as designed I won't feel compelled to fix it right away. And it is still better than Shiba's Armstrong Power Steering.
/ Yanmar 336D Power Steering Question #4
My 3110d is easy to turn even with a bucket full. Something is wrong with your ps if it's hard to turn
Thanks. Kenmac. Valuable info. So, any idea what causes that? My first guesses would be worn hydraulic pump and worn steering gear. The tractor supposedly only has 1014 hours on it.
/ Yanmar 336D Power Steering Question #6
Does your 3110 have the gearbox power steering? My 2002d will turn pretty good with a bucket full to if on hard surface but it won'd in soft dirt. Talking about standing still.
Yes, gearbox power steering. Stiff on a solid surface with an empty bucket. It's downright brutal as the wheels near the travel extremes.
Any thoughts on diagnosing this? The loader works, but is a little slower to lift than I expected. It's the factory loader, original to the machine. How does one test for low hydraulic pressure?
/ Yanmar 336D Power Steering Question #8
That's right .If I remember correctly. I think I read in the manual that there is a seprate pump for ps. I'll have to look it up
Ok, It's not a seprate pump. According to the book , the hp hyd line runs through the diverter block.The book mentions something about a relief valve and a flow control valve within the diverter block. You may need to check the hp from the diverted block and see if any or how much flow you are getting to the ps
/ Yanmar 336D Power Steering Question #9
You would have to find a HP port or cut a T into the HP line and install a guage for measuring hyd. pressure. The guage would need to go to 3500-4000 PSI
/ Yanmar 336D Power Steering Question #10
FYI The p\s on my 336 is easy at all times. Full buckt,dry pavement,grass surface no matter,you must have an isssue. Service might be agood starting point,the screen in the back and full fluid change with new hyd oil is an inexpensive place to start,might help the ldr and the p\s
From CT
/ Yanmar 336D Power Steering Question #11
The 3110D I purchased had a diverter valve unit that failed. its a little (aprrox 5 inch square) box - I think with 4 lines attached bolted to the engine block. I replaced it and the steering has been easy ever since, even stationary - loader full or empty. Probably serviceable but I just swapped it out - my unit originally may have been mis-shimmed.
Being the sister of the 336 if you have cleaned the hydraulic lines, filter(s) and have fresh fluid - try it.
It cost me about 150.00 if I recall and well worth the performance added.
/ Yanmar 336D Power Steering Question #12
My p/s is very easy also its 1 finger operation most always under most conditions. And like Winston I am cautious turning with a load and sitting still. I usually move a bit at the same time turning. And by load I mean anything close to max weight what the loader will handle with dirt in bucket or the pallet forks on like 1.5k#.
The only reason is - I know that if I never break this tractor I will never have to work on it and subsequently have to try and find possibly obsolete parts. ;)
I would check the diverter block also and try out the 3 pt if neither is working properly it could be a stuck open relief valve in the diverter block or even a plugged hyd filter. Maybe even a weak pump but check the easy things first and a pressure test like Kenmac mentioned may be mandatory for anyone here to help further? hth
Thanks everyone for the great info.
The plot thickens. On further inspection, I find that only the PS and lift are on original hydraulics. The loader and some accessory cylinders used as lift arm adjusters are powered by a crank-driven hydraulic pump under the battery. It's a pretty slick addition and I didn't recognize it for what it is until I started investigating a little aux. reservoir tucked under the front.
I guess what that means is that I can't use the loader as a point of reference. The lift works well, even with a 5' HD brush mower.
Things to check:
hydraulic fluid, filter, screens
diverter valve
Where are the rear hydraulic screens located? I am without a service manual for now.
/ Yanmar 336D Power Steering Question #14
/ Yanmar 336D Power Steering Question #15
Diverter block is for sure my hunch at this point or a defective/leaking steering spool valve in the steering gear or stuck open p/s pressure regulator valve. And I say the spool valve presuming this is has one and it probably does since its an all in one unit. I have the manual I will look at it and see and post back.
It should be pretty easy to tear this valve down and see if anything is stuck in its bore. Lay it out on a bench and be super careful to lay it all out and not let any springs etc get away from you.
/ Yanmar 336D Power Steering Question #16
There is control valve within the steering column.But, the relief valve and the flow control valve are within the divider block. I would check the divider 1 st to see if your even getting flow/pressure to the steering unit Per the manual....the flow control valve in the divider block assures priority in oil supply from the mail hyd pump to the ps unit. the controlled flow to the ps system is 1.5 gal. reguardless of engine RPM
Priceless info. Thank you. I wish this issue had a more obvious solution. The steering has loosened up some since I started putzing around on the tractor. But it's still really stiff toward the travel extremes.
I should try lifting the weight off of the front wheels and turning the steering wheel. I suppose the issue could be mechanical binding. This tractor has been used pretty hard, by the looks of it.
/ Yanmar 336D Power Steering Question #19
So what did you figure out on your steering? Just curious!!
Having more time to observe the issue I'm inclined to agree with the theory that the issue is the hydraulic divider valve. The symptoms are precisely consistent.
It hasn't been a high enough priority to get it replaced so far. It's just annoying.
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
2016 Cadillac CTS Sedan (A61574)
2016 Cadillac CTS...
CASE INTERNATIONAL 3020-25' TERRA FLEX GRAIN HEAD (A63291)
CASE INTERNATIONAL...
PALLET OF MISC PARTS (A63291)
PALLET OF MISC...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
