Yanmar 2610 Transmission Fluid Leaking - Please Help!
   / Yanmar 2610 Transmission Fluid Leaking - Please Help! #1
jwweathers
Huntsville, AL
Yanmar 2610
I am new to this forum and tractor ownership. I recently purchased a Yanmar 2610. I noticed some fluid (transmission fluid, maybe?) leaking from a hole beneath the seat (see pictures below). Please give me a hand figuring what this is. Is it a problem? How do I fix it? etc...
Thanks in advance for the help!
Jeff
   / Yanmar 2610 Transmission Fluid Leaking - Please Help! #2
Welcome to the forum. :welcome: Your bottome pictures shows a plug? Looks a little deformed. Will that come out? You need someone with a 2610 parts manual to look and see what that is.
   / Yanmar 2610 Transmission Fluid Leaking - Please Help! #3
Do you have this Vent Tube like on my Ym2000 which would be just out of the #1Pic.? Check and see if it's plugged up. When I first bought mine it was clogged by ether a Dirt Devil or a Wasp/Bee. That could cause enough pressure for that to happen. You may not even have it so it's just a Guess. Yanmar Tractor Parts: AXLE BREATHER (VENT) TUBE_
   / Yanmar 2610 Transmission Fluid Leaking - Please Help! #4
i think it should have a plug in it as it looks to be the end of a shaft, does anyone else have a 2610 that could see if theirs has a plug in it?
   / Yanmar 2610 Transmission Fluid Leaking - Please Help! #5
Grabbing at straws. JD used Yanmar to make some tractors in the past. You might look at 870 series or maybe the 850 series parts diagrams to see if anything looks familiar. John Deere - Parts Catalog
   / Yanmar 2610 Transmission Fluid Leaking - Please Help! #6
That is the other end of your PTO shifter shaft. We just got in a 2610D parts tractor so I took a couple pictures of what it has. It looks like your shaft has pulled out of the housing a little.
   / Yanmar 2610 Transmission Fluid Leaking - Please Help! #7
does that shaft go all the was across ? if so there may be a way to tap it back where it belongs from the other side ??? Just a thought, might even be a way to secure it from the other side,
Aaron can you tell by the parts tractor how it holds the correct position ? just a thought
   / Yanmar 2610 Transmission Fluid Leaking - Please Help! #8
After looking at our parts tractor again, there is a little cap that goes into the hole where the end of your shaft is visible. Our parts tractor's cap is a loose fit right now so it turns a little with the shaft. I thought it was the end of the shaft I was seeing. The part you need is in stock (link below)
Yanmar Tractor Parts: COVER 15
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
Craftsman YTS 3000 42in. Riding Mower (A49346)
Craftsman YTS 3000...
2 Row Cultivator (A52128)
2 Row Cultivator...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52128)
Kuhns AE10 Small...
