Yanmar 2420D Value
/ Yanmar 2420D Value #1
mjsbv
I have a question about what to expect pay for a used tractor. I found a 1985 2420D parked nearby with Koker 160 FEL and Dual backhoe. The tractor has 548 hours on a 4 digit clock. I saw no signs of leaks, engine and transmission oil looked good. Started up and ran fine with no smoke when cold. Everything seemed to work fine, drove and shifted nice but didn't test 4x4 function. Tires are shot (sun checking and worst one from scrubbing something) but for light use will probably run for several years. There is some light cosmetic damage...cracks in instrument cluster bezel and such but paint appears original with sun fading but no rust. Asking price is 9k. Seemed a little high to me but I don't have a good estimate on the value of the hoe. What should I expect? I have no reason to suspect it has been rebuilt and seller (not a dealer) said it wasn't.
Thanks
mjsbv
/ Yanmar 2420D Value #2
A picture would really help if you want an accurate opinion.
/ Yanmar 2420D Value #3
YM2420 last made in 1983 according to the books we've seen from Japan.
/ Yanmar 2420D Value #4
Thanks
mjsbv
I would want to know where the tractor came from ( where did he get the tractor?)
Ok here are some pictures. The story is it came from a dealer in WA who imported it from japan. Let me know what you think.
mjsbv
/ Yanmar 2420D Value #6
mjsbv
Good looking tractor. If you like it & everything works ,go for it.It appears to have shuttle shift. We here, can't tell much about the tractor as ,we haven't heard / seen it operate. There are some web sites where you can check the price. good luck. it's kinda like buying a used vehicle. you never know what can happen
/ Yanmar 2420D Value #7
mjsbv
By Looking at the loader valve, your tractor came from Kowlitz tractor in Wa state. They have since gone out of business (2 yrs ago) I speak with Paula the former owner every now & then.
With the backhoe, and the koyker loader ( IF ) everything checks out, its not a bad deal in my opinion
Ernie
/ Yanmar 2420D Value #8
I have a 2220D, they are identical in almost every respect, dimensions, wheel base, capacities, number of gears, etc. The 2420 weighs around 100 lbs more and the engine is a turbo.
So far my 2220D has been a very good tractor and does everything I have asked it to do.
I think the price is good. Go check it out and make him an offer.
/ Yanmar 2420D Value #9
The 2420 is a 3 cyl non-turbo engine.
/ Yanmar 2420D Value #10
I was just going by what "my" book says. I have an operations manual from Murray Publishing Co. it lists the Ym series 1720-4220 tractors.
I quote the manual " 3 cylinder inline diesel. 3T84H-NA TURBO." All other engine specs including displacement, valve clearances etc are the same as the 2220 series tractors. It also states that the 2420 has 24 PTO HP, and 28 enginge HP, which is two horsepower more than the 2220 tractors.
Maybe your right, i'm pretty new to the Yanmar tractors and learning a little more each day about them.
/ Yanmar 2420D Value #11
Maybe you got the numbers turner around, YM4220 has a turbo.
Danny
/ Yanmar 2420D Value #12
Danny
I suppose I could scan the pages in question.
I'm not trying to beat a dead horse but...............again, my manual says that the YM2420 with engine 3T84H-NA, the YM2820 with engine 3T84-NB, and the YM4220 with engine 3T84T-N all have turbo. I don't doubt that what you are saying is right because it is my understanding that the letter T in the engine ID denotes a turbo'd engine.
Does anyone have the Murray Publications Manual that I have? Publication ID is MC#YM-20-N. And if so does your manual say the same thing or is it just my manual that has a typo?
/ Yanmar 2420D Value #13
If you pay Murry to print a manual, they will print what you tell them to print. My info comes out of the Yanmar parts book. The 3T84T is in the Yanmar YM330 and the YM3000 and they don't have a turbo. The YM3810 has a 3T84T and it does have a turbo.
Danny
2017 CATERPILLAR 980M WHEEL LOADER (A65056)
2017 CATERPILLAR...
2026 323W Stand-On Mini Wheel Loader Skid Steer (A66734)
2026 323W Stand-On...
PALLET OF LIFTING STRAPS (A68842)
PALLET OF LIFTING...
2018 JOHN DEERE 320G SKID STEER (A65056)
2018 JOHN DEERE...
2023 WEILER S350 SKIDDER (A65056)
2023 WEILER S350...
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
