yanmar 186d new purchase
   / yanmar 186d new purchase #21
Lubrication. One point that I know of that several folks miss it the front axle pivot on the main frame under the engine.
It is often neglected, there is a zerk for both front and back bearings, be sure to check or they will be wiped out easily, especially with a loader on.
Well, I've certainly missed it. I've had a 276D for 2 years now and have yet to find those zerks. I have a manual and have found everything else.
I just looked again--no joy. A pic or any help would be greatly appreciated.:confused:
   / yanmar 186d new purchase #22
My YM240 (2wd) has obvious zerks at the front and back bushings supporting the axle-center hinge.
When I got my YM186D I asked this question, and was told that the bushings are sealed with internal gear oil slopped up there.
   / yanmar 186d new purchase #23
On a 186 (2 wd) there is a grease fitting on the side of the pin bushings in the axle. The 186D does not seem to have a grease fitting that I can find, but the 1510, 1510D has a grease fitting in the end of the center pivot pin. Another difference between the 186 and 1510?:D
Mike
   / yanmar 186d new purchase #24
186D has a bushing with o-rings . Pin and bushing are splash lubricated from the differential. Works great , no grease needed.
   / yanmar 186d new purchase #25
Well, the pin on my 276D looks lubed to me, so maybe it's lubed from the dif.
The manual says to grease it---Wouldn't be the first time a manual was wrong, however.
I love my 276D--does twice the work that my MF 65 did. 4x4 & 12f speed powershift make all the difference.:cool2:
   / yanmar 186d new purchase #26
Buppie is correct. I had the same question on my YM186D.
It is splash lubricated from the front diff.
Yep......no fittings on the 186D....4 wheel drive. I have the service and parts manuals......No fittings on the 4 wheel drive model. :):)
Well.....it's been a couple of weeks and I took the advice many of you offered. My 186D has had all the fluids and filters changed. Found several issues....water in the trans. fluid.....gear oil that was very low and probably never changed.....fuel filter totally full of gunk.....very black engine oil and an oil filter that hasn't been off in years.....an oil leak in the front drive shaft/axle housing.......several broken grease fittings and others that hadn't had grease in years......broken head lights and a couple bad fuel lines. That's the bad news......the good news.....everything has been repaired and/or replaced. Hoye tractor has been great to deal with.....they had everything I needed. I have a few bruised knuckles and a bump or two on my head from putting in a new seal on the drive shaft....but most importantly......I have a nice little running tractor right now......looking forward to using it. Still have a little smoke.....I am using Power Service Diesel Kleen right now.....will use for a few tank fulls. Someday.....might have to do the rings.......not anywhere near that bad yet. Life is good!:thumbsup::thumbsup::thumbsup:
   / yanmar 186d new purchase #30
Well.....it's been a couple of weeks ....looking forward to using it. Still have a little smoke.....I am using Power Service Diesel Kleen right now.....will use for a few tank fulls. Someday.....might have to do the rings.......not anywhere near that bad yet. Life is good!:thumbsup::thumbsup::thumbsup:
What color is the smoke? Is it running smoothly or crapping out at high RPM?
rScotty
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
PREDATOR  2IN GAS WATER PUMP (A52472)
PREDATOR 2IN GAS...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
