Yanmar 186D loader hydraulic filter
   / Yanmar 186D loader hydraulic filter #1
suburban99
Hey all just bought a Yanmar 186D with a KMW loader. Model is K650.
Tractor has a PH8A filter remote mounted for what appears to be the hydraulic system.
I know that a PH8A is a ford motor filter. Is this the proper type of filter for this application?
Here's some pictures. thanks
   / Yanmar 186D loader hydraulic filter #2
Nice!! If that's what was on it. Who ever set that up new what they was doing. Not big on Loader manufacturers but looks to be well built!.....
   / Yanmar 186D loader hydraulic filter #3
Ph8a will screw on to many hydro systems from what I read but it can bust cause it's burst pressure is not as high as a true hydro filter. I have also heard brought up that point that it can suck it closed internally due to the increased pressure. I would buy a true hydraulic filter for it.
   / Yanmar 186D loader hydraulic filter #4
I have the same bush hog. That was before they put the big yellow sticker on it.
   / Yanmar 186D loader hydraulic filter #5
Well don't put one on there again. Me or the prev. don't know what were talking about!! It may collapse or explode........ Sorry about that then:confused2: And just gave the Prev, a :thumbsup:
   / Yanmar 186D loader hydraulic filter #6
I'm not saying remove it today cause you can die in the explosion. Just that when I replaced it I would use a proper hydro filter. It would suck to have a filter bust while you were trying to get a job done on a Saturday.
   / Yanmar 186D loader hydraulic filter #7
:laughing: Have to find KMW. Ontario I noticed... A little help but nothing I've found on FEL.. Just go to NAPA and get a Generic match would be safest............. That ones been on there awhile and that little loader not all that much..
   / Yanmar 186D loader hydraulic filter #8
I'm thinking that is the original YFL650 loader which was the 'Yanmar' loader for the YM186. The loaders Yanmar used were made in Canada from what I remember. I have not seen any with the KMW brand on them before but it sure looks a lot like (ok... identical to) the YFL650.
The filter setup is just the regular YM186 hydraulic filter.
   / Yanmar 186D loader hydraulic filter #9
The filter is on the suction side of the pump so no fear in the filter over pressuring and blowing up. Aaron can correct me but I believe the hydraulic filters should be in the 20 micron area. Using a filter with a small micron rating could lead to starvation of the pump.
   / Yanmar 186D loader hydraulic filter #10
I got curious (also own a YM186D) and found Baldwin lists the hydraulic filter for this application: Baldwin B2. Baldwin shows it is a broad-application oil/hydraulic filter.
Then back into NAPA's crossreference table. NAPA's version of B2 is NAPA 1515.
Specs on NAPA's site:
Link: Part Details
including :
Height: 5.197"
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
This seems to be the oil filter widely used by Ford and others '57 to Y2K.
(I see also Baldwin mentions a similar 'short version', and NAPA has a similar '2 quart' version.)
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2017 CATERPILLAR...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
M & M 5 Bottom Plow (A50515)
M & M 5 Bottom...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
