Yanmar 1700
/ Yanmar 1700 #1
warrior1942
yanmar 1700m
Lift leaks down, only picks up about half-way. Fluid level is okay and there are no leaks that I can find. 90 gear oil was used before , I cleaned filter and screen, and used tractor hydraulic fluid to fill. Any help would be appreciated.
/ Yanmar 1700 #2
If you have QD on the loader, check them out.
Is the 3pt lever in neutral or not at the top of travel?
You could use a hyd gage and check for pressure.
/ Yanmar 1700
No loader, travel is at the top.
Thanks
/ Yanmar 1700 #4
Have you checked filters and screens?
Do you have air in the fluid from a suction leak.
/ Yanmar 1700
screens and filters are clean.
Thanks
/ Yanmar 1700
You're my kinda guy. ger er done
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
(1) UNUSED 12" RUBBER TRACK (A64280)
(1) UNUSED 12"...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
46" X 51" TRUCK BED SEAT PLATFORM (A64280)
46" X 51" TRUCK...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
