Yanmar 1700 Idle high
   / Yanmar 1700 Idle high #1
Anthony2010
joeanthony2010
Hi fellas I'm new in the forum. Im coming for help . I bought a Yanmar 1700 (2 cylinders) and came with one injector pumping fuel (just a little) and the other nothing. After inspection I found out that the fuel pump has the fuel conntrol rack stock. I pulled out and found the dry side stock and the rack not moving probably the last owner put it back wrong . I took it apart and have everything moving again but after i installed the pump again and start the engine the idle was crazy high and the governor wasn't slowing it down or shutting it off at all . I have to close the valve in the filter to cut off the fuel. I will post a picture and please tell me if its okay like that or something is backwards. I need help with the back side the front is simple . I will appreciate your help .
Moderator can close the post if want to. I solve the problem . The plungers was backwards the dot they have goes down not aligned with the dots in the gears.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
HYD AUGER W/ 10" BIT (A52708)
HYD AUGER W/ 10"...
1972 Chevrolet Cheyenne 10 4x4 Pickup (A57453)
1972 Chevrolet...
CHALLENGER MT 525B TRACTOR (A58214)
CHALLENGER MT 525B...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
