Yanmar 1700 Idle high
   / Yanmar 1700 Idle high #1
Anthony2010
joeanthony2010
Hi fellas I'm new in the forum. Im coming for help . I bought a Yanmar 1700 (2 cylinders) and came with one injector pumping fuel (just a little) and the other nothing. After inspection I found out that the fuel pump has the fuel conntrol rack stock. I pulled out and found the dry side stock and the rack not moving probably the last owner put it back wrong . I took it apart and have everything moving again but after i installed the pump again and start the engine the idle was crazy high and the governor wasn't slowing it down or shutting it off at all . I have to close the valve in the filter to cut off the fuel. I will post a picture and please tell me if its okay like that or something is backwards. I need help with the back side the front is simple . I will appreciate your help .
Moderator can close the post if want to. I solve the problem . The plungers was backwards the dot they have goes down not aligned with the dots in the gears.
2008 Ford F-150 Ext. Cab Pickup Truck (A56858)
2008 Ford F-150...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
JOHN DEERE 348 SQUARE BALER (A58214)
JOHN DEERE 348...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
5' ROTARY MOWER (A52708)
5' ROTARY MOWER...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
