/ Yanmar 1510 steering drag link #1
pdetterman
Yanmar 1510
Hey guys, I bent my steering drag link real bad on my old Yanmar 1510. Home Tractor Parts doesn't have one in stocker in their boneyard, and they can't tell me to use one from a different model (for legal purposes I'm sure, and I get that). But the rep also told me to come over here and ask around for suggestions. Like, is there a tractor that uses the same size shaft? Or maybe I could just use a tie rod with the same length??
As you can see, it is suppose to have a slight bend in it normally, but mine is so bent now, I can only turn left.
Thanks in advance
   / Yanmar 1510 steering drag link #2
If you can’t find parts, you can make a new link. Center your wheels and steering wheel. Measure the distance between the center of the ball joints. Cut the ends off your existing link. Bend a new piece out of similar matteral using the pictures as a guide to get it close then weld on the old ends. It is a tractor so it only needs to be close. Cam
   / Yanmar 1510 steering drag link #3
I have YM1510 parts tractor email me
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
