Yanmar 150d workshop manual/ loader manual
   / Yanmar 150d workshop manual/ loader manual #1
boltz
Ontario Canada
kioti ck30, allis d-17, Cub Cadet Enforcer Zero Turn Mower
Just acquired red 150d yanmar tractor with fel. Seems that this is rare model? Parts manual that came with it says YM155d not 150d as on hood. Phoned Hoyle in Texas and they said never heard of this model. Grey market? Looking for drag rod for steering linkage and some other parts. Would any one out there have a repair manual or able to advise me about this little guy. (It runs great after we drained the water out of every thing, and changed fluids) since it had been left out in field over winter. Changed 4 hoses on loader. Loader is really slow up and down and curl . Is there a filter in reservoir?) I know very little about tractor hydraulics, but did change fluid JD303 spec. and cleaned screen Thx Boltz
   / Yanmar 150d workshop manual/ loader manual #2
Probably a 1500D, not 150D. Post a photo and we'll have a look see.
Will get my better half to post some pictures, tomorrow if possible. I'm not great on computer stuff. Have tractor at work. Tractor looks almost identical to YM 155D model on front of factory parts list manual that I was given with tractor. Thx
   / Yanmar 150d workshop manual/ loader manual #4
Are decals, etc. printed in English or Japanese?
Took pics today and wife said will try to get them to upload. Decals are 90% English, but was told by Hoye that engine serial number was near starter (left side of engine). No serial number there, unless you have to remove starter to see number on engine block. There is what looks to be a missing serial plate maybe, that was on the left side of transmission tunnel, that maybe fell off due to age or weather. There is a number that starts with YM13000 or YM1300D-0xxx below where missing decal or plate was that is stamped into tunnel. Also on right side of tunnel ,near diff lock if memory serves is plate with Japanese script on 3 lines and YM?300D. Middle line above has 880 and script on both sides. I am reading this off her phone right now and if she is not too busy will post pics Wed. Sorry to take so long on pics. Thx (In pics front tires are mounted with tread backwards, haven't got to that yet):rolleyes: The more I research this tonight, I am beginning to think it is a YM1300D, mostly due to stamp on trans tunnel but there is 150D decal on one side of hood that I have been using as the model reference, incorrectly I guess, and also because past owner gave me Yanmar parts list for YM155D. Her husband passed away and he was the original purchaser, so wife is not 100% sure about data. Pardon my rambling, but may have have answered my own question. Will post tomorrow. Boltz
   / Yanmar 150d workshop manual/ loader manual #6
Used to be a dealer who posted here often about his frustration with 'Frankensteinmars', Yanmars "Factory Reconditioned" in VN assembled out of diverse parts. (And those shops have no access at all to genuine Yanmar parts). Said he often got blamed when he shipped parts that didn't fit - because the person ordering actually owned something different from what he thought it was. Sounds like you will need to do a little detective work before you order maintenance stuff for it.
Next to your left ankle is where Yanmar stamps the model and serial number for the tractor. Sounds like you have a YM1300D.
But if that hood was put on it later from some other Yanmar, or at least the model badge, then its worth your trouble to verify the engine also is for YM1300. On most Yanmars there is an engine build plate riveted to the block in front of or above the starter. Or it could be up on the valve cover, either side. If that plate is missing there's a reason for it and I would look carefully at YM1300D manuals to verify that your engine is the right one. Most of the small Yanmars are pretty well supported but you will save a lot of frustration (for dealer too!) if you have identified the actual model engine etc you are buying for.
Lots of photos here will help. Other members own that model and can point out details. This is a pretty helpful bunch.
Hey Wayne - you still read this forum? :thumbsup:
   / Yanmar 150d workshop manual/ loader manual #7
Yep sounds like a 1300D. Verify that it has the correct engine which without looking it up will be a 2TR13. ;)
20160412_172055.jpg20160412_172055.jpg20160412_172103.jpg20160412_172110.jpg20160412_172115.jpg
Still having trouble trying to get rest of pics on, but better half says will give it a go again tomorrow, and I know better than to argue. Thanks folks.
2015 FREIGHTLINER CASCADIA DAY CAB (A52577)
2015 FREIGHTLINER...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
Reg Cab Box Truck (A50120)
Reg Cab Box Truck...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52748)
Kubota BX2680...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
