Yanmar 1300d
/ Yanmar 1300d #1
4wnitro
Yanmar 1300d
I have a Yanmar 1300d tractor it just wants to run at full throttle. When I first got it I had to replace the starter switch and bleed the air out of the fuel system. It ran fine I could increase and decrease the speed of the engine. It sat for 7 months and now it just wants to run at full throttle.
/ Yanmar 1300d #2
You have a Gray Market tractor. So it's difficult for people to relate.
Ask in the vintage Yanmar section, you'll get fast and good answers.
/ Yanmar 1300d #3
The inj pump control rack is probably stuck from old fuel.
If it has a side plate right below the inj pump, remove it to gain access to the inj pump control rack and try to move it back and forth..
Bump the engine to get it on other cylinders and try moving it back and forth..
Don’t force it to much.!!
Just about everything is brittle..
Good luck
2019 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A66736)
2019 Peterbilt 579...
2015 PETERB/ILT 320 6X4 T/A GARBAGE TRUCK (A66091)
2015 PETERB/ILT...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2008 FORD CROWN VICTORIA  CAR (A66091)
2008 FORD CROWN...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2012 SPARTAN GLADIATOR FIRE TRUCK (A66091)
2012 SPARTAN...
