yamnar 2000
   / yamnar 2000 #1
bruce60
Frisco
yanmar2000
Yamnar 2000 seems to be starving for fuel. It dies when in gear or just idling. It ran great today for about an hour. Thanks.
   / yamnar 2000 #2
Plenty of fuel? Clean fuel filter? No trash in tank where outlet goes out? Fuel cap loosened to prevent vacuum?
Was in running normal until today?
"It dies when in gear or just idling." It will run with throttle open and not in gear?
   / yamnar 2000
I will try gas cap remedy and post. Thanks.
   / yamnar 2000
Fuel cap remedy didn't work.
   / yamnar 2000
Will try. Thanks.
   / yamnar 2000 #7
If your old rubber fuel lines haven't been replaced,, now is a good time to do it.. They will go bad
   / yamnar 2000 #9
I had this problem when I first bought the 2000. On your Throttle arm hold it in place so it don't fall. Or keep your foot on the Throttle pedal. There's a Nylon washer in the Throttle linkage that goes bad, You can adj. it by the lock nuts. If that's the problem .
8ft Perforated Metal (A51573)
8ft Perforated...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
City of Lakeland (A51691)
City of Lakeland...
