Yamaha ATV brake drum nut?
   / Yamaha ATV brake drum nut? #1
redka
Middle GA
The nut that holds the rear wheel brake drum on... is it left hand or right hand thread?
Trying to get the drum off to see what might be the reason the wheel won't turn, but can't break the nut loose.
Thanks
   / Yamaha ATV brake drum nut? #2
Redka,
Google it, you will most likely find your answer on the threads. Most likely right, but not sure.
On another note, give it a good soaking of Blaster. That stuff works great on frozen bolts and nuts.
Craig
Thanks. Already gave it some PBB. Will try again with a bigger wrench and longer pipe lever.
   / Yamaha ATV brake drum nut? #4
hand thread?
You don't say what model you have.
None of the ATVs I have had use left hand threads on the rear axles, and I have had all the majors
except Can-Am.
If you are trying to remove the nut on the end of the axle (after removing the cotter pin), then
those are rarely tight, and "always" RHD.
If you are trying to remove a jam-nut in the middle of the axle, then you will probably need
to heat it first. These are huge nuts, often set with thread-locker. I use a 2-foot adjustable
wrench, and a homemade wrench for the lock nut. Even that does not loosen them without
heat first.
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
2022 CATERPILLAR 279D3 SKID STEER (A51246)
2022 CATERPILLAR...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2019 FREIGHTLINER...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2020 RoGator RG1300C Spreader (A53342)
2020 RoGator...
