Y'all Been Checkin' Lumber Prices?
/ Y'all Been Checkin' Lumber Prices? #1,385
I remember buying a full meal at McDonalds and getting change back from a dollar.
I didn't say I was THAT much of an antique. I do have two McDonald's glasses, yes glass, that has hamburgers for $0.15, yes 15 cents. So maybe that's from back in your day. Now, all I can say is I remember way back in the day, I'd get a meal from McDonald's and get change from a twenty....
/ Y'all Been Checkin' Lumber Prices? #1,386
McDonalds rival, Henrys Hamburgers, used to sell them 10 for a dollar.
/ Y'all Been Checkin' Lumber Prices? #1,388
Yes, and those hamburgers were full size.... not the size of a 50 cent piece! ...and costing almost $2 now.
/ Y'all Been Checkin' Lumber Prices? #1,389
In Eau Claire, Wisconsin, in the fall of 1967, McDonalds hamburger were 15 cents, and the sign bragged "Over a Million Sold"
/ Y'all Been Checkin' Lumber Prices? #1,390
Been there, done this after a night of carousing back in the day. Actually it was cheaper way, way back in the day. Too fuzzy to remember the price. Quality never mattered. 🥹🥹
/ Y'all Been Checkin' Lumber Prices? #1,392
I haven't read all 1400 posts in this thread, but, what are lumber prices doing now? Have priced peaked and starting to come down? Or, are prices still rising?
I will be starting on a 30x20 enclosure to add a office/kitchen to my shop in about 2 weeks.
/ Y'all Been Checkin' Lumber Prices? #1,393
They seem to have stabilized and even relaxed a bit, but I won't be expecting to see it back to it's original prices. $5 2x4's in **** condition are the new normal.
/ Y'all Been Checkin' Lumber Prices? #1,394
That's good to know.
Is the Home Depot rebate a check I can cash or a voucher that can only be redeemed on my next purchase?
It's a gift card, that lasts forever. You can get a physical gift card mailed to you, or just get an online code emailed.
/ Y'all Been Checkin' Lumber Prices? #1,395
As long as it's intended purpose isn't for building things. There's a reason it's cheaper. It's not only **** with water, it's heavier and weaker. A buddy of mine had a house built. Paid a fortune. Stucco over osb. "but with proper waterproofing..." 7 years later it was shot. He had to have ALL the stucco removed and a good amount of the osb replaced and put vinyl siding on, to the tune of $150k. He sued the builder and the builders insurance covered most of it, but it was a nightmare.
There's no way to keep everything moisture proof forever. Even humidity affects things. Sure, plywood may not last forever but it'll last a hell of a lot longer than OSB. There's a reason brick buildings are still standing 100 years later. Maybe you're a bit long in the tooth but I still plan on hanging around a good while longer. And I want anything I build to not only last my lifetime, but my children's lifetime.
I mean, we all learned from your garage build thread that you have your own particular building preferences, lol.
But this is kinda silly, man. You friend's disaster example only informed us that they did a **** job on the stucco and didn't waterproof the wall assembly. Its not like if you had sh!tty stucco leaking water into a plywood sheathed wall, that this would somehow be fine or desireable in comparison.
OSB isn't really any heavier than plywood. 7/16 sheets are easy to toss around. It cuts easily and doesn't delaminate like plywood layers can. Keep your OSB in the roof and walls dry, like it always should be, and it lasts forever. And saves you a ton of cash while building.
I'd rather use plywood most of the time also, but not for twice the price.
/ Y'all Been Checkin' Lumber Prices? #1,396
They tanked to what it was this time two years ago, and now are stabilizing for the time being. Once the tariffs come off Chinese goods they may drop more.
/ Y'all Been Checkin' Lumber Prices? #1,397
My generator shed was also built in osb, and waterproofed, tar paper, screened, stucco'd, and 6 years later, the osb is rotting. Double the price sure, but in the grand scheme of things in the project it was a drop in the bucket.
I used 102 sheets of plywood on the walls of my garage. I'm up to about 105k on the garage, the bulk of which was pre-pandemic prices. At current prices, that's $5510 to use plywood vs what, $2750? Similarly, my chicken coop I'm using plywood over OSB. I'm up to about $3000 on the coop, 3 sheets of plywood is $165. Saving $75 on the course of the project.
If all you're buying is osb vs plywood, maybe the price matters. But in the grand scheme of things, wouldn't it be better to save money elsewhere?
/ Y'all Been Checkin' Lumber Prices? #1,398
Chinese wood :oops:
/ Y'all Been Checkin' Lumber Prices? #1,399
Maybe. But I think the problem is the stucco, haha. OSB kept dry under normal siding doesn't just rot spontaneously.
I put some pretty new, but re-claimed OSB on a temporary pole barn 10 years ago. I painted it with good exterior paint - no siding or anything else over it. Fast forward to this year, and I pulled some of it off for re-use on my new shed, because it's still completely intact. The pieces of OSB that I leave laying around with no protection seem to last about 2 years in the weather before being total junk. But I honestly can't say that scraps of plywood fare any better, in my experience. It's stronger in a wall assembly, no doubt. But I've seen it rot just as much when left out in the rain.
/ Y'all Been Checkin' Lumber Prices? #1,400
I find scrap pieces of OSB make good landings at the bottom of porch steps. Say 3’X3’ pieces on the ground. Not as good as concrete or pavers of course but good for a couple of years. Somewhere to knock your feet off.
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
30in Hydraulic Pallet Forks Mini Skid Steer Attachment (A59228)
30in Hydraulic...
2024 CATERPILLAR 305CR EXCAVATOR (A60429)
2024 CATERPILLAR...
KBH Tender (A61307)
KBH Tender (A61307)
2017 CATERPILLAR 420F2 BACKHOE (A59823)
2017 CATERPILLAR...
UNUSED ZJG ZJ-08 MINI DIGGER (A60430)
UNUSED ZJG ZJ-08...
