YAHP(Yet Another Heat Pump) Question/Issue
   / YAHP(Yet Another Heat Pump) Question/Issue #1
dmccarty
Super Star Member
Triangle Of North Carolina
JD 4700
<sigh>
I guess it is our turn.
Our 13-14 year old Goodman HVAC system has a leak. The HVAC guy was out today, and since our unit has the older refrigerant, we need to have a new condenser and evaporator. <sigh>
Long story short, the condenser unit is a good 65 foot run to the evaporator which is not efficient but there is not much we can do about it. Will adding more insulation around the refrigerant line help increase the system efficiency?
Thanks,
Dan
   / YAHP(Yet Another Heat Pump) Question/Issue #2
Their is some gain but it's minimal. If I had a few hours and $100 to spend on increasing my home's efficiency I wouldn't start there.
Btw- the older refrigerant is available. It is possible to find the leak and repair just that part. You don't need new everything because of an undiagnosed leak. You may want a second option before you drop several thousand bucks. They can add dye to the system that makes finding the leak fairly easy- typically with a UV light. Good luck.
   / YAHP(Yet Another Heat Pump) Question/Issue #3
If you do go the insulation route remember fiberglass as near zero r value with any air movement. You will need to stick to the foam or other commercial type insulation.
I was guessing that while it was not the most efficient configuration it really was not that costly. The bigger issue was how they installed the systems in the attic but that is another story and not worth fixing either. :(
The repair guy put in some refrigerant a few weeks ago and it leaked out pretty quickly in about a week. At this point, is it worth patching up a 14 year old system, especially a system that uses the old refrigerant which will eventually not be available and is expensive now? :confused3:
Just got a cost of $5,800 to replace the condenser and evaporator which seems high to me...
Later,
Dan
   / YAHP(Yet Another Heat Pump) Question/Issue #5
While their is some energy loss in the lineset that does benefit from insulation, it's minimal. Most of the magic happens in the evaporator.
Refrigeration Cycle Tutorial: Step by Step, Detailed and Concise! - YouTube
As far as replacement- It sounds like your system was working fine sans the leak. Your tech should have added some dye to the system so you know where the leak is. This is a common thing to do when adding refrigerant that leaked out. You may have a leak at a fitting or something simple and spending $5800 would be a waste of money. Even if the leak was at the evaporator I'd just replace that part. Once you get into a failed compressor or condenser then you need to crunch numbers- fix vs replace. But at this point you have an undiagnosed issue. It's troubling you brought in a tech who was more interested in selling you new than telling what's wrong.
The whole refrigerate shortage scare is overhyped. My buddy still has bottles of R-12 (1980s tech) thinking he would need it- what a waste of money! Before I dropped $5800 on new I'd find out what is wrong. If it's simple, fix it. If you are paranoid about not having refrigerant have the tech sell you a bottle to keep for yourself. Worst case you wait a few years and sell it on eBay when the hysteria really kicks in.
As far as $5800- that sounds high ballpark. A "good" salesman (who is a good teacher) should give you at least 3 prices. The tract home version, the custom home version and the top of the line over the top version. With cost comes increased efficiency. Their will be a sweet spot for your area. If electricity is cheap and you have a well insulated home and mild climate- skip the fancy stuff. If you run your AC/heat pump 24/7 and you have tiered electrical costs then the custom home version may be your best bet. Rarely is the top of the line in efficiency worth the cost- that is reserved for folks who want to be on the cutting edge irregardless of cost. Ask what the company owner and or his techs have in their house.
Btw- brand and price point have little to do with how long a product will last. Most of the stuff contractors install- that they purchase from the local wholesaler is fine quality- Ford vs Chevy vs Toyota vs Honda etc.
   / YAHP(Yet Another Heat Pump) Question/Issue #6
Unless the leak is on an aluminum coil it should be repaired and the unit charged properly. Ask that another tech with more experience be sent to locate the leak and make the repair. With an electronic leak detector the leak can be found in less than 30 minutes. Techs are often given incentives ($$$) to condemn units and pass the info on to a company salesman.
Guys, thanks for the info.
We certainly do not need a higher SEER unit, unless there was no price difference over a lower SEER system. The guy has asked if we wanted to price out an American Standard system but I would think that will be more money and what would we be getting in return? We will ask though.
Getting old refrigerant and a decent price is certainly one of our concerns. If this is not that big of an issue it does change priorities a bit.
We are going to ask some more questions to the company, which is a simply two man operation, not a large company, and get a second opinion.
Part of the cost might be because of our attic access. We have a fair amount of room up there with 6 foot height but part of the HVAC is on one side of the attic that has ceiling joists 16 inch on center that limits moving big stuff from one side of the attic to the other. I really can't believe that passed code, the code inspector was a stickler on interpreting code in some painful ways, and one would have thought this would have been an issue. Anyway, it was something I was going to correct a few years ago but got in a car accident which cost me 9 months of not being able to do physical work, so the this attic issue got pushed aside....
Thanks again,
Dan
   / YAHP(Yet Another Heat Pump) Question/Issue #10
If I had to bet, your leak is in the evap. coil, or accumulator..
The price quoted may not be a bad price. Depends on the size and difficulty of replacement.
Remember. You can have the R22 removed and replaced with R407C as a replacement.
My farm house has 2- 2004 10 seer Trane units (R22 refrigerant) when they go. They will be upgraded to higher SEER units
As for the long run. I have a 2 story house. The unit upstairs is probably a 60 foot run on the refrigerant lines.
Insulating the suction line won't do much good as everything has already taken place in the evap coil. the refrigerant is headed back to the compressor to start the cycle all over again.
You likely have a piston orifice in the old system. I really like TXV's as they monitor refrigerant flow to the evap coil instead of always spewing refrigerant in the coil at the same rate no matter what.
You system has some age and a recp. compressor. you repair the leak today. Tomorrow you replace the compressor. Before you know it, you have put enough in your old unit, you could have bought a new system
Which ever you choose. Good luck
2021 Chevrolet Express (A53317)
2021 Chevrolet...
2025 Mower King SSRC72 (A56469)
2025 Mower King...
2003 International 9200I (A56469)
2003 International...
2015 Deere 524K (A53317)
2015 Deere 524K...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
