Yahoo!!!! Got tractor, etc.!!!!!!!!!!!
/ Yahoo!!!! Got tractor, etc.!!!!!!!!!!!
Your tractor sure looks like a Fredricks Equipment Reman. Those are the new tires they install. All the yellow warning decals are also a give away. UTDA Approved, click this link to compare. They sell it for $5995 without loader, plus $3295 for loader
Yanmar Tractors -- Parts -- Sales -- Service
http://fredricksequipment.com/Portals/0/2210D.jpg
It came from LMTC.......I have the receipt. I paid a little less...:) I do believe it's worth the money to buy from a place that gets A grade machines, re-do them here, and use U.S. built loaders. That's exactly what I was gonna do, but got this one for several thousand dollars less..............couldn't justify spending $$ I don't have!!
/ Yahoo!!!! Got tractor, etc.!!!!!!!!!!! #22
yep, I think LMTC gets his tractors from Fredricks.
It's good to know I got a nice unit........I field mowed over four acres of rough stuff yesterday. Hilly, lots of trees and rocks, tore off one of the hitch stabilizing turnbuckles. I mean tough. Burned around two gallons in five hours of continuous operation. Almost unbelievable, the machine is a BEAST. I'm considering naming her Fiona. As in "Princess Fiona". "Cause she's a little ogre of a tractor.....not the prettiest, but man, what a worker!!!!!
/ Yahoo!!!! Got tractor, etc.!!!!!!!!!!! #25
Wow thats good how many acres does that equate too. I can mow a little under an acre an hour and will use about 2.5-3 gallons for the same time i think in my 2000
I had just filled the tank as full as I could get it before starting. I fired her up and blasted through from 11:45 to 4:45. When I filled her today, only two gallons!! It took pretty long because I have some hairy hills; I had to use low gear or lug.
/ Yahoo!!!! Got tractor, etc.!!!!!!!!!!! #27
I'm mostly mowing flat ground with a 4 ft bushhog. I am mowing in 7th gear. I have a gear tractor with high/low and 4 speeds on each range so i only have one higher gear i can go into.
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2001 FORD F-250 SUPER DUTY (A67714)
2001 FORD F-250...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
2019 INTERNATIONAL DURASTAR 4300 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
