Yahoo!!!! Got tractor, etc.!!!!!!!!!!!
/ Yahoo!!!! Got tractor, etc.!!!!!!!!!!!
Your tractor sure looks like a Fredricks Equipment Reman. Those are the new tires they install. All the yellow warning decals are also a give away. UTDA Approved, click this link to compare. They sell it for $5995 without loader, plus $3295 for loader
Yanmar Tractors -- Parts -- Sales -- Service
http://fredricksequipment.com/Portals/0/2210D.jpg
It came from LMTC.......I have the receipt. I paid a little less...:) I do believe it's worth the money to buy from a place that gets A grade machines, re-do them here, and use U.S. built loaders. That's exactly what I was gonna do, but got this one for several thousand dollars less..............couldn't justify spending $$ I don't have!!
/ Yahoo!!!! Got tractor, etc.!!!!!!!!!!! #22
yep, I think LMTC gets his tractors from Fredricks.
It's good to know I got a nice unit........I field mowed over four acres of rough stuff yesterday. Hilly, lots of trees and rocks, tore off one of the hitch stabilizing turnbuckles. I mean tough. Burned around two gallons in five hours of continuous operation. Almost unbelievable, the machine is a BEAST. I'm considering naming her Fiona. As in "Princess Fiona". "Cause she's a little ogre of a tractor.....not the prettiest, but man, what a worker!!!!!
/ Yahoo!!!! Got tractor, etc.!!!!!!!!!!! #25
Wow thats good how many acres does that equate too. I can mow a little under an acre an hour and will use about 2.5-3 gallons for the same time i think in my 2000
I had just filled the tank as full as I could get it before starting. I fired her up and blasted through from 11:45 to 4:45. When I filled her today, only two gallons!! It took pretty long because I have some hairy hills; I had to use low gear or lug.
/ Yahoo!!!! Got tractor, etc.!!!!!!!!!!! #27
I'm mostly mowing flat ground with a 4 ft bushhog. I am mowing in 7th gear. I have a gear tractor with high/low and 4 speeds on each range so i only have one higher gear i can go into.
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
10ft Cultivator (A65579)
10ft Cultivator...
New Holland 463 Disk Mower (A66408)
New Holland 463...
Caterpillar TL1055D (A62177)
Caterpillar...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
