xuv 620i gator
/ xuv 620i gator #1
fog482
xuv620i
Gator 620i is fuel pump relay under the dash? 1 is start relay Anyone know other 2? No power to green wire feeding red wire on elec. fuel pump. Can't find green wire origin. Been working on this for a week. Can't find if there is a fuse either, but all fuses I found were good. Did tap into pump green wire & added switch to hot wire to battery & pump works. It's just the power to the green wire that's got me stumped. All help would be appreciated. Hate to0 spend 40- $50 for manual w/o knowing if answer will be in it. Thank you.
/ xuv 620i gator #3
Fuel pump appears to be key 28 along that wiring harness.
The wiring diagrams are likely in the service tech manual, not the operators manual.
And welcome to TBN
/ xuv 620i gator #4
Here is the Technical Manual for you Gator, however it does NOT include a wiring diagram or a schematic.
Richard
  • John-Deere-XUV-620i-Gator-Utility-Vehicle-Technical-Manual.pdf
